02-19-2019 08:47 AM
04-27-2020 01:03 AM
Hi RickMG,
On certain Samsung devices, we have run into issues with one of the default settings.
In your settings under the Wi-Fi settings, look for the ADVANCED option. Once there, you should see the AUTO NETWORK SWITCH. This is designed to allow the phone to roam seamlessly from available Wi-Fi networks to cellular data, but it does interfere with our Wi-Fi devices. Try disabling this option, and see if that makes a difference.
If problems persist, I would suggest that you email us at the email below, and be sure to detail what camera you have and what steps you've tried in the email:
eosdigitalsupport@cits.canon.com
Troubleshooting Wi-Fi issues can take be a little more involved in some cases, and email works a little better for that.
04-27-2020 01:06 AM
05-04-2020 12:54 PM
05-04-2020 02:58 PM
Nick,
Thank you for the info. I have written for more help and hopefully will hear back from Canon. I do not have the AUTO NETWORK SWITCH in my advanced wifi settings but do have Turn on Wi-Fi automatically which is already disabled. I can still connect with my old phone (which doesn't have service (a Galaxy S8+) but not on the Galaxy S20+ 5G, their newer phone. Thank you again.
Rick Green
07-09-2020 12:25 PM
07-09-2020 12:52 PM
@Rana1993 wrote:
Make sure you are entering the correct camera. I have a Canon Rebel t7 and it took me forever to figure out i couldnt just enter 2000D. I had to put EOS in front of it
You want to initially use the default camera name.
11-06-2020 06:05 AM
I've tried this on a 90D. Makes no difference at all. The app and the camera won't connect. SO what now?
01-10-2021 08:51 AM
01-25-2021 11:50 AM
Hello,
I have used the canon connect with my Canon EOS 80D and my iPhone 6s for a year. However, today when I connect to the camera's wifi and open the app, and try to view images to download the app crashes. I have uninstalled the app from my phone, restarted my phone, and reinstalled the app (didn't change anything). I have redone the wifi set up on the camera from the beginning again (didn't change anything). the app does say it is connected to the camera and allows me to click on the "View images" button but immediately crashes after I press the button.
Does anyone know how I can fix this?
Thank you
01-25-2021 12:26 PM
Beginning a year ago I attempted unsuccessfully to operate my Canon 6D with the Canon Camera Connect Smartphone App . I was following the (Easy Connect) process for Wi-Fi and even though my network status on the phone showed connection, the App never would recognize the camera. After a couple of weeks I gave up. Two weeks ago upgraded to the Canon 5D MK4 and was unable to get the Camera Connect “Easy Connect” to work on this camera either. However, the 5D offers another method of connection that was not available on my 6D, that is called (Connecting to a NFC Enabled Smartphone). NFC stands for (Near Field Communication). Turns out my LG Android phone is NFC enabled, the connection process is a breeze and the Camera Connect app works perfectly. You can turn on NFC by going to Settings>Connected Devices>NFC. I’m not familiar with Apple but I believe NFC is available on the IOS platform too.
