DR-C240 Scanner not detecting ZONE characters
Mikevj007
After updating drivers and installing the optional module for OCR;
-I've set the area to pick up a 6 digit number to use as part of the filename to save the scan.  Testing the detection in the 'area settings/properties' window works every time.  However, there is no detection during the scan.  I've tried the older OCR module dated 2-1-24 too.
-Output settings for filename include the detection result.
Any ideas?  Is there a newer unpublished OCR module?
1 REPLY 1
ArthurJ
If you are running CaptureOnTouch Pro5 there is this file Optional OCR module for CaptureOnTouch V5 Pro that can below installed from the support page HERE
If the issue persists, WWe will have to recommend that you call our support team at 1-800-423-2366, Monday - Friday, 8:00 AM - 6:00 PM EST (excluding holidays)
We look forward to hearing from you.
Friends and Family
