07-10-2025
12:08 PM
12:12 PM
I have a CanoScan LiDE 220. I am attempting to use it to scan artwork. The scanner usually does a good job, but sometimes it strips out magenta or orange from an image. I assume this is caused by something in a software setting, but I'm not familiar enough with Canon's software to track it down. Here are example images. The first (blue) is from the scanner. The second is a photograph of the same piece from an iPhone and the color is fairly accurate. Any ideas on how I can get accurate scans? Thanks!
Scan of dragonfly painting
Photo of dragonfly painting
07-12-2025 07:03 AM
Added info: I'm running MacOS 15.5 and attempting to use Canon IJ Scan Utility2 Version 2.4.3.
07-15-2025 04:31 PM
Hi what_fresh_h,
Please try calibrating your scanner. To do this , please follow these steps:
1. Open the IJ Scan Utility2.
2. Click on the Driver button.
3. Place a check mark in the "Calibrate before each scan" box.
4. With nothing on the scan bed, click the "Scan " button at the bottom.
Perform this 4 or 5 times and then attempt to scan your item again.
07-20-2025 09:45 AM
Thanks for responding! I checked the calibrate box and scanned 5 times empty. After that the scans of the painting still removed the magenta. There was no significant difference from the original scan that I posted.
07-22-2025 02:58 PM
Hi what_fresh_h,
As a test , do you have another computer that you could install your scanner on and try a test scan?
That would help narrow down the cause.
07-27-2025 01:42 PM
Hi Patrick,
I was getting the same results previously on a Mac running OS 13. I waited to dive into the problem until after I got a new computer, in case the old computer was the problem.
I've also tried scanning with Image Capture and get the same results.
07-28-2025 04:32 PM
You can try removing and reinstalling the scanner driver but if that does not resolve the issue, I recommend reaching out to Canon support. You will need to register your Canon gear HERE to access additional support options.
We look forward to hearing from you.
07-28-2025 05:41 PM
Thank you for your response. I have tried uninstalling and reinstalling, with the same result. I have registered my scanner, and the only way that I can see is to access support is to pay $19.99. That seems a bit unreasonable when the product seems to be at fault. I was going through the process of getting help to see if I was interested in upgrading to a better Canon scanner, but this reads like a firmware issue, which doesn't leave me optimistic that I can purchase a Canon scanner that will work well to scan watercolor paintings.
