‎12-17-2022
03:03 PM
‎12-20-2022
09:23 AM
I have always used Print Studio Pro with my Canon printers - with no issues. Suddenly it doesn't print in either Lightroom or Photoshop. It appears that the printer recognizes the file as the file name appears in the printer LCD and the printer appears to be getting ready to print (all of the usual noises and advancing the paper to print). However, it just ejects the paper without printing. I have uninstalled and reinstalled ALL of the Canon printer drivers - the problem remains.
I am able to print from both the Photoshop and Lightroom "Print" dialog so I do know that the printer is communicating with the computer.
‎12-23-2022 07:05 AM
I did solve my issue yesterday - maybe only temporarily. I saw in Print Studio Pro that there are two Printer options - Canon XPS and Canon Printer. I swear that I always had it se to XPS but changed it to Canon Printer and it seemed to solve the problem. I'm not sure why or if it is the real fix - but I'll take it. It is comforting to know that I'm not the only one who has struggled with this.
‎12-23-2022 01:29 AM - edited ‎12-23-2022 01:30 AM
I'm having the same problem with Print Studio Pro. My printer is a Pixma Pro-10, but I am having the exact same problem as the orignal poster. I've also tried everything, uninstalling and reinstalling the printer multiple times. I also uninstalled and reinstalled Print Studio Pro, but the issue persists. I too am able to print using other apps, but for borderless printing I prefer to use Print Studio Pro.
If it matters I am using Windows 11 22H2.
‎12-23-2022 06:52 PM
Hmmm... I guess I'll try that.
However I wonder what printer driver it ends up using, the standard driver or the xps driver. Using the standard driver color bit depth is limited to 8bits per channel, xps is 16bits per channel so it will have a wider color gamut. I'll give it a try though for now. Thanks for the tip!!
If that is indeed the problem then Canon needs to fix this problem. What's the point of having a really good printer if it can only print a standard color gamut.
‎12-23-2022 07:52 PM
Thank you again for posting this tip. I tried it and it worked for me. I think it is still using the the XPS driver. When I couldn't get Print Studio Pro to work a couple days ago I tried Easy Photo Print Ex, another app that is available from Canon. That worked, but the color seemed a little flat. I just tried your tip with Print Studio Pro and it gave me the results I was expecting.
Thanks again!!
‎12-23-2022 08:54 PM
I've been searching Print Studio Pro insights for use with the Pro-10 printer. I'm using the most current version of Windows 10 Home and Photoshop 2023 and just installed (and uninstalled/reinstalled several times in hopes of correcting an error) Print Studio Pro 2.2.3 manually into Program Files/Adobe/Adobe Photoshop 2023/Plugins and was prompted it successfully installed. When I try and launch Print Studio Pro from Photoshop's Automate menu PSP does try and start but then it issues a prompt that "An error has occurred. Exiting Print Studio Pro." I have rebooted Photoshop, my computer, uninstalled and reinstalled and I just can't get PSP to initialize as expected. Interestingly, the Layout Plugin for PSP does function properly.
I came across a user that indicated that PSP is old and has been replaced with Professional Print & Layout but that software doesn't seem compatible with the Pro-10 as I can't get it to find a printer to use -- I'm pretty sure now it only works with the ImageProGraph printers.
Is anyone using Print Studio Pro successfully with Photoshop 2023, a Pro-10, and Windows 10? I'm about to abandon this plugin since I cannot get it to work. Thanks for any advice.
‎12-25-2022 01:56 PM
I have a PRO 1000 and when printing from Photo Shop latest version it works fine with either the standard 8 bit driver or the 16 bit driver which is the XPS driver. Now if I try to print from the Canon Print Studio Pro plug in.....the standard 8 bit version works fine but if I select the 16 bit version it passes the print paper through the machine without printing. The PRO 1000 is a month old and has all the current updates so appears to be something in Print Studio Pro that is the culprit. May not be a huge difference between the 8 and 16 bit versions of the print.....most likely the blue and purple colors have a bit finer variations (smoother) but mostly imperceptible. Still would be nice to have the ability to print from the Print Studio Pro as it has some nice features.
‎12-25-2022 02:04 PM
I have the same issue with my new PRO 1000. I can print in 16 bit with the XPS driver if I print directly from the latest version of Photo Shop CC. But if I try to print the same thing with the XPS driver and the Canon latest Print Studio Pro it only passes the paper through the machine without printing anything....if I select the 8 bit driver it works fine although of course slightly restricted color gamut. I spent a few hours trying to debug the issue....looks like it is the Print Studio Pro that is the problem. So for now will use the standard PS print operation but wish I could use Print Studio Pro as it has some nice additional features. Hope Canon can address this bug or advice or a work around.
‎12-25-2022 02:07 PM
Forgot to add.....I did install the plug in correctly and it does work under PS and both driver options are shown in Print Studio Pro...but not able to print with the 16 bit XPS driver version.
‎12-27-2022 02:05 PM
This is NOT the fix for Windows users. We are able to print using Canon Studio Pro and the 8 bit driver....but the 16 bit version (with XPS added to the driver name) still won't print from Canon Studio pro in either PS or Light Room. if we use the same 16 bit driver in the regular Photo Shop or Light Room print command it does work. I just spent about 30 minutes on line with Canon support and showed them the issue. The issue is real as I demonstrated so they are going to look into it. Hopefully they can figure it out....either a bad 16 bit driver or some issue between the driver and Photo Shop and Light Room...or perhaps Windows. For the time being if you need 16 bit image prints use the Adobe print option in the respective programs.
