Professional Photo Printers
ccanada by Administrator
  • 3158 Views
  • 0 replies
  • 1 likes
Color problems with Canon Pixma PRO-10
I have owned this Canon Pixma Pro 10 for almost a decade now with very little use because I’ve never been successful in getting it to print colors properly. I am a stationer and was hoping to use it to print invitations, but the only time I’ve ever b...
Canon pixma pro 100 color not right
 I used this printer for my illustration. But the color seems faded/incorrect. I run the color test and didn’t see any abnormal. I’m still waiting for the paper I order but I see ppl use watercolor paper to print too. So I tried that and did not like...
Kitty320 by Contributor
  • 3081 Views
  • 8 replies
Resolved! Horizontal White thin lines on Pixma PRO-200
Hello,I'm printing from Affinity Designer on card stock paper 80 Lbs with my new printer and I see very thin horizontal white lines sometimes spaced as close as 3/32" (near top and bottom edges of sheet), most of the time spaced around 5/8". Some par...
AtomTik by Apprentice
  • 3613 Views
  • 2 replies
Canon Pixma Pro-100 muddy colors?
IMG_1731.jpegHi,Wanted to ask if anyone knows how the ink starts mixing with each other? When I do cleaning and print nozzle check, it comes out like this. Magenta goes to the yellow and photocyan specifically. thank you!
Borderless Printing for 5.5 x 8.5 cards
I have a Pro-200 and have been able to print my cards on 5.5 x 8.5 with no border. I am using Photoshop and evidently a setting has changed and I can no longer get my cards to print without borders. I have tried every setting I can find and have had ...
mouser by Apprentice
  • 8706 Views
  • 3 replies
Pro9000mkII - Does Not Work With Windows 11
I can't get it to work on my new machine.  I've installed the drivers, gone to Device Manager and updated the drivers (it said the best ones were already installed).  When I select it as the printer and send the print it says 'printer not responding'...
Resolved! Cannot Install Pro-1000 Driver (Windows 10)
I'm on Windows 10 19042.985 Recently purchased and set up a Pro-1000. I was able to connect to the Wi-Fi network through the printer itself, and Windows can find my printer. I can also find the printer when I go through the setup wizard. Problem is I...
Epos7 by Contributor
  • 10539 Views
  • 10 replies
  • 1 likes
