01-29-2024 10:10 PM
Hello,
I'm printing from Affinity Designer on card stock paper 80 Lbs with my new printer and I see very thin horizontal white lines sometimes spaced as close as 3/32" (near top and bottom edges of sheet), most of the time spaced around 5/8". Some parts of the documents seem fine.
I have tried to print jpeg but I have the same result.
I ran a nozzle check test and saw nothing wrong.
I would appreciate any help. Thanks.
02-14-2024 04:50 PM
Hi Arthur,
I actually reached out to Canon support and the solution was to print as photo. The only drawback is that the colors are much darker this way. I'm testing other brands of paper right now and I seem to get better results.
Thanks!
02-14-2024 08:29 AM
Does this only happen when printing on Cardstock?
If you would like assistance in real time, I recommend reaching out to Canon support. You will need to register your Canon gear HERE to access additional support options.
02-14-2024 04:50 PM
Hi Arthur,
Thanks!
