03-27-2026
07:27 AM
08:39 AM
Hello, I've been having some trouble with my printer (a g7020 megatank) for the past few weeks and wanted to see if anyone else had any insight as to how I might fix it. It jammed while I was printing stickers with it and since then there's been white horizontal lines across anything I print in color. I thought maybe replacing the printhead would fix it, but with the new one it has trouble printing blue ink - on the test sheet, the first line for Cyan is completely blank, but the second, lighter line prints fine, and every other color (including black) also prints completely fine.
I'm at a loss for what to do to fix it, none of the maintenance options on the printer seem to do anything. I've run regular cleaning and deep cleaning several times to no avail and running an ink flush didn't make a difference either.
03-27-2026 11:09 AM
This sounds like a tough one to repair, ink seems to not be getting to one of the cyan nozzles, you replace the print head so it should not be the source of the clog, but the part of the printer that feeds one of the cyan nozzles ls is no longer working correctly. Did you do a deep cleaning of the new head?
03-29-2026 04:55 PM
I did a deep cleaning on the new head, yes. The cyan ink prints fine with the old head with the exception of the horizontal lines that appear in all three colors so it seems to be a problem with the new part itself? I tried aligning the print head and that made the colored ink misaligned now, is there any way to undo it?
The ink levels are all at about half and the paper that got jammed didn't tear when I removed it, so there shouldn't still be any debris blocking anything..
03-30-2026 12:15 PM
Hi LadyGwenifur,
It would appear that your PIXMA G7020 would require service. If your PIXMA G7020 was purchased less than a year ago, please contact one of Canon's Technical Support Representatives via phone or chat to obtain your in warranty options. To contact a Technical Support Representative, please use the link below to log into your My Canon account:
https://mycanon.usa.canon.com
Once logged in, click on your PIXMA G7020 and then click on the Product Support button. When that page loads, click on either the Phone Support button or the Chat Support button to access support.
If your PIXMA G7020 is out of warranty, you are eligible for Canon's Upgrade Program. This is for out of warranty units which have been diagnosed to require service, or for some reason are incompatible with a new or upgraded system. This option allows you a one-time opportunity to purchase a replacement product, discounted from the list price.
If you would like to take part in this option, please call our Sales Department at (866) 443-8002 Monday through Saturday, 9am to 9pm. Let them know you have been working with technical support and the Canon Upgrade Program was offered.
