Professional Photo Printers
How to Get the Most from Canon’s Software Tools for its Professional Inkjet Photo Printers Getting a print to match what you see on screen isn’t magic - it’s a process. And a big part of that process happens in the software. Whether you’re using the...
ccanada by Administrator
  • 3167 Views
  • 0 replies
  • 1 likes
Pro 1000 Color cast on prints
I have a Canon PRO 1000. It has printed perfectly until very recently. Now all my prints come out with a yellowish caste/tint to them. I have a calibrated iMac monitor using the Datacolor SpyderX Pro. I have calibrated the printer in the maintenance ...
paaflyer by Contributor
  • 24331 Views
  • 22 replies
Resolved! Canon Pro 100 - test page/nozzle check missing
I have had several Canon Pro 100s since 2014 - I bought them dirt cheap in 2014 and 2015. I just set up one, fresh out of an unopened box, as the previous one is no longer working. Using Mac Sierra on iMac without a CD drive. After the usual hassles ...
tway by Apprentice
  • 7145 Views
  • 4 replies
18 flashes on Pixma Pro-10
I am trying to use my pixma pro-10 after years of non-use. I'm getting 18 flashes. I tried the chatbot but it kept sending me hardware set-up guides. I don't understand why. What is the issue? What does 18 flashes mean? They used to have a simple tro...
swamper by Apprentice
  • 1352 Views
macOS Monterey ProGraf-1000 Pro Magenta Cast
I have a new ProGraf-1000 Pro and it has a strong magenta cast under all conditions:- Ps CC and Lr CC up to date- Using Canon and Mateo paper with their ICC profiles- Screen is calibrated- 16 bit mode on or off- Printer managed or Application Managed...
Proclivis by Contributor
  • 10678 Views
  • 12 replies
PIXMA PRO-200 - does no print gray
I want to print text in gray and it prints in light pink, even if I select to print in grayscale.I have updated drivers. How can I fix it? This has been happening to me forever, I have had the printer for a year. Thanks for your help.
PIXMA PRO-200 error code 6004
Hello,I would like to know what does the above error code mean once the unit powers on. Can this be fixed w/o professional servicing ?Please let me know what I can check for.Thanks,filosad
filosad by Contributor
  • 1562 Views
Resolved! imagePROGRAF PRO-1000 - won't print on 4x6
My first several prints were to 4x6 and it worked fine.  After blowing through the first round of ink and then replacing all of the ink, it won't print to 4x6.  Spent some quality time with support and determined it prints fine with any other size of...
DFDPete by Apprentice
  • 2261 Views
imagePROGRAF PRO-1100 Factory reset
I have a prograf 1100. The password was changed from the factory default. The password is lost. How to I perform a factory reset? The procedures in the manual require the password. Unless I can reset the passsword the printer is useless.
JPM by Apprentice
  • 7186 Views
  • 7 replies
  • 1 likes
