01-09-2015 02:24 AM - edited 01-09-2015 02:25 AM
Hello all!
I have several Canon Pro9000 and Pro9000 Mark II printers. The Pro9000 Mark II printers are doing great. However, the Pro9000 printer is printing photos with a heavy blue cast to them. The blue is so heavy and so bad that any photo printed with it is destroyed.
I have tried printing both from Photoshop and from other programs, including straight from Window's photo viewer. When printing from Photoshop, I have tried both letting Photoshop manage colors and the printer manage colors. When Photoshop is managing colors, I've turn color management off for the printer (set it to None). I've made sure I have the proper paper selected, etc. It does not matter what I do, the Pro9000 still prints with a heavy blue cast.
I've tried switching from Auto to Manual in an attempt to reduce the blue. But even if I have the first slider (labeled Cyan) slid all the way to the red side and the third slider (labeled Yellow) slid all the way over to yellow, I am still getting a heavy blue, but now the images are too red and too yellow, etc.
What can I do to figure out what is going on with this printer? It used to print properly, so I am not sure what changed. Any help would be much appreciated.
Thank you.
PS - I am running Windows 8.1, 64-bit.
01-09-2015 11:59 AM
"I uninstalled and reinstalled the Pro9000 drivers and rebooted. It has not fixed the problem."
This doesn't not surprise me as it rarely is a driver causing your condition.
"I don't have any 9500's."
OK, sorry for the confudion I meant 9000 and 9000 Mk II, of course.
It is odd that both of the printers is doing the same thing. Both are printing blueish! Let me recap. All is good to go with the 9000 Mk II's and the computer and monitor all all on board? Hmm, I am wondering if the two are conflicting each other? Maybe the 9000's are using the 9000 Mk II's drivers? Can you uninstall the Mk II's and try again.
If it were not both printers, I would have said the print head is toast but I suppose both could go at the same time. Don't waste any more ink cleaning.
01-09-2015 12:02 PM
01-09-2015 03:36 PM
I know and I would normally agree but it is something to try. At least disable it and see but I believe you will have to completely uninstall it to be certain. Each driver can a different UI but still revert back to one to print.
It is puzzleing that it happens to two machines at the same time. It almost has to be the computer.
01-09-2015 03:43 PM
01-09-2015 03:44 PM
01-09-2015 03:45 PM
01-09-2015 03:48 PM
01-09-2015 03:50 PM
01-09-2015 04:06 PM
Am I to understand, two different printers? Several computers? Plus any software doesn't matter? ![]()
You do know how impossibile this is?
You have a bad supply of ink. Are you using genuine Canon ink? Or, I am back to my first thought, the print heads have failed.
01-09-2015 04:09 PM
