01-08-2015 10:36 AM
I have some early prints where I mis-sized the image and ended up with a lot of extra white left over. Can I run it through again and print to the unprinted areas?
01-09-2015 10:37 AM
"Can I run it through again and print to the unprinted areas?"
Yes you can I do it all the time. But ONLY after the print has completely dried. I mean DRY! Several hours is required. If you get ink all over the printer's rollers and/or paper path, you will not be a happy person.
01-08-2015 12:21 PM
01-09-2015 10:37 AM
01-09-2015 03:46 PM
Ahh--that's what I was worrying about was the risk of fouling the rollers/paper path. I dry sheets between paper for several days. Once they're dry....
01-10-2015 09:24 AM
"Once they're dry...."
Go fo it. ![]()
