Pro-100 cyan extremely light
johninar
I have cleaned the print head and tried to figure out why cyan is so light. Suggestions?IMG_6614.jpeg
jrhoffman75
If you have performed Deep Cleanings and still don’t get the cyan channel my guess would be a failed head.
But, as a check, be sure that there isn’t any of the clear wrap on the top of the cyan cartridge. There is a tiny vent hole on top. It can be blocked if there is wrap in top.
5 REPLIES 5
jrhoffman75
milobluefoot
Hello,
I'm new too and I may have a similar problem with a Pixma Pro100S.
The Cyan and Photo Cyan are just absent. I runned several deep cleanings but nothing changes. I also noticed the inside of the printer is filthy with cyan ink...
Should I just clean everything and do a manual cleaning of the printhead (with ammonia) ?
Thanks very much for your suggestions
@milobluefoot wrote:
Hello,
It may be perspective, but it looks like the two cyan cartridges are sitting different than the others. Are you sure they are seated correctly?
johninar
Thank you, I was suspecting a failed print head as there is no streaking or lines in the print. It's smooth, just very light. I am ordering a new print head.
Thank you,
John
Did replacing the printhead fix the issue?
I think I'm having the same issue with the Cyan. Thanks.
Friends and Family
