01-14-2020 08:26 AM
The Premium Fine Art Smooth profile shows as "registered in printer" in the media configuration tool, but when I physically look for the Premium Fine Art Smooth profile on the physical printer, it is not there.
However, the Premium Fine Art Smooth profile does show up in the driver in the printer settings when I want to print in Photoshop.
Will the driver overwrite the printer?
Does anyone know why I can't find the profile in the physical printer? Do I need to find it if it shows in the driver?
Thanks
Below is a screenshot showing the profile appears to be properly loaded in the printer.
02-08-2020
06:21 AM
08:24 AM
Tiffany
I can confirm that on my printer the LCD did changes and prompt asking the paper size/type when detects paper inserted on the manual feed tray.
I did a very short video but couldn't upload it… you can check it here:
<Removed per forum guidelines>
Hope it helps.
02-08-2020 09:56 AM
Hy Jx,
Just in case we're talking about two different printers, I am using the Canon Pro-1000. Is that the same one you are using?
02-08-2020 10:38 AM
Yes, same printer.
