Pixma Pro 100 Printing Issues with macOS Big Sur
katiegarrison
I've been using my Pixma Pro 100 for 5+ years with a PC with no issues. I switched to macOS Big Sur, and now I'm getting blurred/hazy prints. I've tried printing through PhotoShop, Gimp and ColorSync. Here are the other things I tried with no success:
  • Deleted all printers/reset printers in Apple settings and readded Pro 100 with Canon IJ using latest drivers downloaded from Canon (did not use AirPrint or Bonjour to add the printer)
  • Tried Canon’s plugin Print Studio Pro in Photoshop
  • Hooked the computer directly up to printer with USB cable and tried to print
  • Updated the printer’s firmware to the latest version
  • Cleaned printer multiple times using Utility
  • Cleaned print heads manually
After all this, I hooked up my PC again, and it printed perfectly. Any advice?
40 REPLIES 40
THANK YOU, THANK YOU, THANK YOU!!!!!
I have not been able to print on 13X19 paper for several years. I have searched for answers and the air print issue solved everything!
Thanks for this. My printer was using air-print as well. When I applied icc profile in Lightroom, colors were awful - as though profile was applied twice. Best I could do was let the printer manage color.  With the Correct driver (Canon as you mention), I now have the color options, and can use icc profiles as before.
This is the driver version from Canon directly mcpd-mac-pro_100-16_50_0_0-ea21_3.dmg.
Big Sur did something to make Lightroom fail to display all the previous settings such as paper type selection.
LV
LV
Lightroom Classic and Big Sur 11.6. Here is a screen shot. You need to select the appropriate dropdown.
After I've removed the driver and reinstalled it. Rebooted the mac and everything seems to be working as normal.
I was able to print photos and things are looking good for now. Thank you for everyone help,
LV
jrhoffman75
I’ll private message you when I get home.
Hello.
I printed the file four ways:
1. Lightroom using the Canon PSP plugin on PC
2. Canon DPP photo software using the PSP plugin on PC
3. Canon DPP photo software using the PSP plugin on MacBook
4. Apple Preview software on MacBook.
All prints were the same:
And all are the same as the Mac print you posted:
The PC print looks extra sharpened. If that is the effect you want and you want to use the Mac then maybe you can find a suitable editing tool on the Mac.
I don't have Windows Picture Viewer, but I did open and print the image in Photos app on my PC and the results were the same as the other four.
Thank you so much for working through this. So baffling to me. I'll play around with editing and see what comes of it. Thanks again.
Hi! I'm having all of the exact same problems, and I read through every single part of this forum!
I was wondering if you reached any conclusion or fixed the blurriness?? I'm still experiementing to no avail. It doesn't even matter what file format I print in (pdf, tif, jpeg...)
Thanks!
Welcome to the forum.
I suggest you start a new thread with your situation. I suggest this becasue I am not convinced the OP ebvery really had a problem, and when I presented the various outputs there was no followup from the OP.
Tell us:
1. what operating system and version
2. be sure you have downl;aoded and installed the latest printer driver.
3. if on a Mac, be sure you have the IJ Series driver and not the AirPrint driver
4. what software are you printing from
5. if posiible, post a screen shot of the printer setup dialogue.
6. run a nozzle check on your printer
7. post a screenshot of the poor print out
The more info you can provide the easier, and most likely the quicker , it will be to get to a resolution.
Avatar
