06-05-2022 04:48 PM - edited 06-05-2022 04:53 PM
I was printing fine, until I updated my driver to 16.50.0.0. Now, blue is printing as purple. I am printing from Lightroom Classic, and I've checked the printer settings, have the correct ICC, and paper type, etc. I ran a nozzle cleaning and the print test look good. Any suggestions? I have tried both my Kirkland cheap paper and my Canon Pro Luster (with same ICC), and get the same problem.
Softproof of test image (note blue)
Print of test image - note purple in the blue lane
Print test after nozzle check:
Doing this on a iMac running MacOS Monterey 12.3.1 . I am using the Canon USB print driver.
Any suggestions?
Thanks in advance!
06-05-2022 04:54 PM
Why did you update your driver, new operating system?
What OS. Which driver did you install?
06-05-2022 05:26 PM - edited 06-05-2022 05:35 PM
I had a network security issue, so I had to change my SSID. When I went through reinstalling the network connection for the printer, I noticed that the printer driver was out of date, so I upgraded to the most recent, 16.50.0.0 from the Canon support site. I am on a iMAC Retina 5K, 27-inch, 2019 running MacOS Monterey 12.3.1
I also tried printing the test file as a jpeg directly from the Preview application, and it produced the same exact purple instead of blue - so not a lightroom configuration issue, I think.
