05-26-2022 03:38 AM
My PRO-100 worked fine a week ago. Today, I went to print and got the two orange flash error, which refers to paper not feeding properly. I fiddled with the paper and tried reloading it in every position I could think of, and I still get the two orange flashes. The kind of paper is Platinum Pro, I'm feeding from the top manual feed (not the back). I didn't see a paper jam but I might not have looked closely. Any ideas?
05-26-2022 06:44 AM
It continues to flash after you press the button?
05-26-2022 02:36 PM
Sorry I forget to mention that each time I tried moving the paper a little I pressed the button to restart feeding. It would make noise like something spinning inside. I tried to help the paper along by jiggling it, but it wouldn't move. After three periods of spinning, the two-flash error would come on again.
06-07-2022 03:37 AM
It's working now, although there are still times it doesn't print at all and gives a network error.
What I did to "fix" it was update the firmware. Then I had to fiddle a long time to get it set up again on my MacBook, not sure why all the trouble. I'm not sure any of this has anything to do with the "fix" as opposed to "just started working again."
