10-02-2017 10:32 PM
I am trying to set up a new pixma pro 100 printer using my Mac (10.12). I successfully set up the printer via wifi and installed the driver and the computer has located the printer, but when I follow the instructions to launch the IJ Printer Utility I hit a dead end.
I have tried the following two approaches:
1. Via system preferences > printers > canon pro 100 series > options & supplies > show printer webpage > utilities
All I get as utilities are confirm lan settings and language selection. No head alignment etc.
2. Via Mac HD > Library > Printers > Canon > BJPrinter > Utilities > Canon IJ Printer Utility
All I get is a message "There is no printer available"... but clearly there is a printer available, since I can talk to it via the system preferences.
What do I need to do?
10-02-2017 11:25 PM
09-18-2020 01:31 PM
My Canon Pro 100 can be found on my network but it says it cannot find the driver. I downloaded the driver from the canon website but still nothing. I have been trying to get this thing to work so I can start using it.
I am attaching a screenshot of what the webpage looks like but I cannot figure out how to fix this. Its brand new and my OS is Windows 10. When I click on Utilities, it just shows Language and Confirm LAN settings. HELP PLEASE!!!
09-18-2020 03:11 PM
Welcome to the forum lioness65.
It looks like you are trying to set the printer up as a Bonjour printer. That is a very limited printer configuration.
I suggest you follow the instructions in the guide:
https://downloads.canon.com/wireless/PRO-100_setup.pdf
If you need additional help come back.
09-18-2020 04:00 PM
09-18-2020 06:07 PM
Here is what I would try.
1. Go to Control Panel->Devices & Prinbters and right-click-remove the Canon Pro-100.
Go into Control Panel->Programs & Features and uninstall programs associated with tyhe printer.
Go to the Canon support site and download the latest driver:
Download the second, not the XPS driver.
After you install the driver go to the instructions I linked and see if that works for you.
