12-30-2017 11:38 AM
12-30-2017 01:54 PM - edited 01-01-2018 09:43 AM
Search the web for ICC Color profiles and work flows. Other search terms: RGB sRGB, Adobe RGB, etc
You are correct about potentially removing the settings on the printer as this can change the workflow process at the output stage. Typically you allow the program your are using for editing to manage color space and workflow from beginning to end.
Correct monitor calibration is also important, but ensuring the same color profile throught the entire workflow is what provides consistent results. You will benefit greatly doing some reading to better understand how to control profiles during capture, editing and output. Once you get the work flow dialed in, you will love your printer.
07-13-2018 12:55 AM
I'm helping a very senior friend who has used his Canon Pro 100 with a Mac for several months, with good results.
A couple of weeks ago, he suddenly had a problem with the colors on the Pro 100. Colors were pale and washed out. He only uses Canon OEM ink and prints from Photoshop. However, printing out of Chrome produces the same faded-looking colors as does printing colors in a Word document.
This afternoon, I brought a Win 10-64 notebook and connected to the printer via USB. SAME problme - wathed out colors.
Reading posts on this problem has been NO help. Two different OS computers having identical printing problems would seem to point to the printer as the problem. Any suggestions ?
Thanks for any help -- that will help.
Wolf
07-13-2018 06:59 AM
1. Does it still print OK from the Mac?
2. There is no Chromebook driver for the printer, when printing from Chromebook it’s probably using a general driver that doesn’t utilize all printer capabilities.
3. Did you install the Canon driver on the Windows printer you used?
07-13-2018 10:36 AM
Thank you for the quick response.
The color problem IS the Mac printing. My friend started to have the problem after months of using the printer.
Regarding printing in Windows, I just plugged it in to the USB port without loading a driver. I now know that a special driver exists and will download and try again.
Cannon's support page has Win and Mac drivers for the Pro 100 and I'll try to install them on the respective computers. Of course, that does not explain WHY the printer suddenly started to give my frriend problems after monhts of good use.
Will follow up after installing the drivers.
01-12-2025 08:04 PM
My Pro 200 produces prints only distantly related to what shows on the display: darker and far less color vibrance. For this kind of money, the printer should live up to its advertising, si? We have tried everything a novice can do, texted with people in the know, watched ALL the you tube stuff and reinstalled the printer drivers twice. Using Photoshop CS5.1 (I know it's old, but it used to work just fine for what I needed) The Adobe guy in New Delhi took 45 minutes to determine that he didn't understand the problem and that the CS5.1 version was no longer supported. Then he summarily hung up. Thanks, Adobe. Is there some basic advice for a fix that an old trombone player could understand? Don't want all that much: just white whites, black blacks, and pretty much the same vibrant colors that show up on the display, please. I'll pay . . .
01-12-2025 09:45 PM
You are posting on a solved 7 year old thread about a different printer.
Please start a new thread and state the computer operating system you are using.
12-30-2017 02:32 PM - edited 12-30-2017 02:37 PM
What paper are you printing on? Is it possible you are printing on the wrong side?
What software are you printing from? Can you paste a screen shot of your print settings?
https://www.dpreview.com/forums/post/60570124
12-30-2017 03:05 PM
12-30-2017 04:07 PM - edited 12-30-2017 07:23 PM
This may help, but I do need to know what software you are printing from. That is where you start your print settings.
https://www.dpreview.com/forums/post/60545311
https://www.youtube.com/watch?v=GdbEZk-PtCU
