01-11-2025 10:47 AM
Hi, My previously reliable Pro-100 has started to print lines on my prints. I have tried the maintenance steps to no avail. Can someone help? Thanks, Colin
01-11-2025 11:02 AM
Check your nozzle check pattern. It looks like your printhead has nozzle outs causing those bands.
01-11-2025 03:06 PM
I took out the print head and cleaned it but the bands are still there. Should I replace the print head?
01-11-2025 07:08 PM
Yes, cleaning a Canon printhead manually never works and can usually cause further issue with it. Did you run a nozzle check on it? If there are voids present then that seals it, the head is dead.
