07-19-2021 07:38 PM
OSX 11.4 with bonjour. Great printer, which was SO EASY to setup, and I could print from all my devices wirelessly.
HOWEVER, after a few hours it goes offline. Waking it up manually and then ADDing it as a printer again works...for a few hours, but it always goes offline after a few. I tried a dedicated IP on the wireless network, but was no help. It seems to disconnect (perhaps when it sleeps?) and then won't automatically reconnect.
I put it on a wire, and all is well with my mac which is also on the same wired network, however wireless devices understandably can't find it as thats a different network.
disappointed.
Is this happenning to everyone?
07-20-2021 09:52 AM - edited 07-20-2021 09:54 AM
We ocassionally have to wake these printer up, say after a weekend of inactivity, but day to day using a static IP connected via ethernet hasn't been a problem. All of our printer are connected via ethernet, so I am not able to discern if ths is an issue in our environment.
Sleep mode shouldn't affect the printer's ability to wake. Typically its the routers ARP table that keeps a wireless device from waking. (router doesn't pass wake packets) I would definitely use a static IP and revert any changes to power management and sleep settings if changes were made in the remote UI.
~R5C (1.0.1.1) ~Many Lenses ~DxO PhotoLab Elite ~Windows10 Pro ~EVGA RTX 3080Ti FTW3 Ultra
~ImageClass MF644Cdw ~Pixel6 ~6D2 (v1.1.1) retiring
07-20-2021 11:53 PM
09-09-2021 01:47 PM
Hello Beaudad,
When using a bonjour connection, the computer can sometimes switch to using the generic apple airprint driver system. In this situation, I would suggest, going into printers and scanners and removing any connections from the list using the - in the bottom left hand corner.
Once the printer has been removed, you can try adding the printer again. When adding the printer, make sure the USE drop down box near the add button shows the driver for the printer and not the option for airprint. Once it is set to the name of the printer, you can click add and check if the new connection is more reliable.
If you are unable to select the printer name in the USE box, you can try downloading and reinstalling the UFRII printer driver Found at the link HERE. Once the driver has been reinstalled, you can try adding the printer again to see if you can select the correct driver for the printer in the USE dropdown box.
