is there a way to get mx420 to print documents etc from ipad?
is there a way to print documents etc from ipad iphone, on mx420?
Hi Guys, I am trying to set up myCanon MX7600 printer to print using a wired lan connection. I install the drivers, select from the menu new setup (wired), and it asks to plug in USB connection. I do that, and it says printer detected. It then fails ...
I have an MG6320 on an internal wired/wireless network - can it connect to both at the same time or do I have to select one or the other?
Receiving an error when I attempt to login in to setup the web services.I have registered my product and created a Canon Image Gateway loginUnsure of what else to do
Hi all, I'm wondering whether anyone can help me with a frustrating problem that I'm having with my new printer. I have a MacBook Pro, and I'm running Max OS X 10.7.5 I followed the instructions to the letter, and used the disc provided to aid me, an...
Hello,for 2 days i am trying to install our new Canon MG8250 on one of our Win 2003 Servers. The server is supposed to be in a different subnet then the printer. The driver does search for the printer but can not find it. The driver gives me no optio...
Hi We have a CLC5151 networked and it has suddenly stopped being seen on the network. I can't find where in the settings to go to check / edit the IP Address etc., as under 'Network Settings' all it has under TCP/IP is Certificates and Proxy. I hav...
hello I have an annoying issue with my MP560 wireless printer.Roughly every 2-4 weeks, the wireless printer does not work. It looses its connection.I have it set for DHCP, nothing static. To fix the issue i unplug the router and modem and it works pe...
When I go to the scan tab and press online, it sits there at waiting. Needless to say, I can't scan. Any help will be appreciated it. Thanks. Shane
Suddenly this machine gives this message when attempting to scan: Cannot scan for these reasons: Scanner is turned offUSB cable is disconnected Please check and try againScanner driver will be closed 2.156.0 This is a Mac OS 10.6.8 Can still print ...
I used to be able to use wireless point to print on my MG3100 but after reinstalling the driver it can no longer find my wireless access point. I tried unstalling and resintalling again and have selected Wi-Fi installation. The installation wizard fi...
Hi: this is for pixma mx860 multifunction (all-in-one). Can I go back & forth between wired & wireless connectivity? Problem is that we have 1 tower ethernet wired (only) in our c/s w2K nw, that prints fine that way. Prob. #2 is that we have othe...
I have the MX432 printer. Until recently the printer was working fine. Now when I try to print it says that it is offline. I noticed that the encryption changed from TKIP to AES and that the authentication also changed. How do I get these two ite...
| Subject | Author | Posted |
| 09-15-2026 07:21 PM | ||
| 09-13-2026 07:01 PM | ||
| 09-10-2026 02:37 PM | ||
| 08-14-2026 05:48 PM | ||
| 04-28-2026 08:20 AM |
