Printer Software & Networking
Resolved! D420 Wake on LAN?
I have never been able to allow others on my network to print if my iMac is sleeping - only if I wake it up.I'm wired and now running Big Sur 11.2.2 and thought it was high time to stop this nonsense.Needless to say, I can't figure out how to do this...
StevenZK by Apprentice
  • 2841 Views
Printer Turns On and Off By Itself?
Pixma TS3100 Used via WiFi connections only. Works perfectly.Periodically, when not in use, this printer turns On by itself and makes sounds, and doesn't print anything. Is this a programmed maintenance feature or is someone trying to sign into it vi...
rccanon by Apprentice
  • 3355 Views
My laptop can't find my G7020
I spent a lot of yesterday getting the wireless set up (again!) on my Canon G7020, and then printed some things wirelessly from my (Macbook Air, Mac OS Big Sur) laptop. Today, my laptop keeps saying that the printer is offline. Usually, if I turn the...
Resolved! Wireless printing on PXIMA MX 492
Hello all, Until recently the wireless printing on my PIXMA MX 492 was working just fine. I changed my router, and ever since I have not been able to print wirelessly. I can connect to the wireless network with the printer, as it is able to detect lo...
Resolved! WPS PIN number
HiI've just switched to a new laptop (Lenovo, as was the previous one) and am trying to set up the laptop to connect to the printer.  It's taken two days but when I search for devices the laptop now recognises the printer, but requires the WPS PIN to...
ARH by Apprentice
  • 26072 Views
  • 3 replies
Network setup for Pro-100 printer
This has been the hardest printer to get setup on the network I have ever had to deal with.  The directions are hard to follow too. In any case, I have this printer connected to a Windows 10 Pro machine via USB.  Also to my LAN via Ethernet (when tur...
CGClark by Apprentice
  • 2274 Views
  • 2 replies
Want to undo "Using Only Printer"
I have a new Pixma TR7520 printer. A wireless printer is new for me. Anyway, when setting up I made a mistake in "Preparing for Connection." I pressed Stop as if i wanted to "use only printer." And then, "Do Not Connect." How do I undo such a basic c...
b-b by Apprentice
  • 1546 Views
  • 2 replies
Resolved! Network Configuration Page on a Canon iP7220
I recently changed my Wireless Router and now my printer won't connect to it. I believe the problem is in the Network Configuration of the printer. The defaut gateway of the new router is 192.168.50.1 and the IP Address on the Canon iP7220 printer Ne...
The_Hat by Contributor
  • 5032 Views
  • 3 replies
Computer won't recognize MX492
I've run through the setup process multiple times, and to no avail. I did just replace my modem with a mesh unit, and when I checked out what they had to say, I got a message stating my printer must have this or it won't work: "WPA2 AES-based CCMP en...
