Printer Software & Networking
two printers?
Greetings from Michigan.I have just purchased Pixma ip8720. I ran the setup disc successfully. The problem is that it replaced existing software for my old printer Pixma MG5200. Can I install another program for MG5200? I still want to use the scanne...
sungksoh by Apprentice
  • 1515 Views
Software Problem
I recently purchased a new computer and I have an iMP8400 printer that I need to download software to. The problem I am incurring is that, when I originally purchase the printer the software was for windows 7, now I have windows 10 and the software w...
ts3122 cant change to a new router
I switched my internet/router service from att to Tmobile and there is no way to teach the TS3122 to look for the new wireless network. The new router is not a WPS enabled device. The TS3122 is not a USB cable device. So how do I tell about the new w...
whitemma by Apprentice
  • 5375 Views
  • 5 replies
PIXMA TR8520 Won't Print PDFs and JPGs from PC
I did all the actions above - twice.  Problem not solved:  TR8520 suddenly stopped printing PDFs and JPGs from my Win10 PC:  Still will print word documents, still will print from my wife's PC, still will print from iPhone.  Still says: Printer not r...
3101 by Apprentice
  • 959 Views
  • 0 replies
Resolved! MX479, WIRELESS SETUP, NEW ORBI NETWORK
Hello!I've had this MX479 for a few years now and it's been reliable.  I've run into a few things today that I just can't get around so I thought I would ask you fine folks So, I upgraded my network today from a Linksys EA9500 router to the Netgear O...
Pixma TR8520 driver wont unZip
Recently moved my Pixma TR8520 to a new location (PC) that previously had a TR 7520 on it. I have tried to download the drivers , both the full suite and also the TR8500 series MP Drivers Ver.1.02 (Windows). Every time I try to run or install it I re...
Phakodoc by Apprentice
  • 7073 Views
  • 5 replies
How to Print via Airprint from iOS device
To print from an iOS device, please tap airpint.pngIn the menu that appears, please tap Print print.pngprint.jpgThe Printer Options page will appear.  If your printer is selected, tap Print in the upper right corner.  If your printer does not appear,...
Patrick by Product Expert
  • 3039 Views
  • 0 replies
iPad won't connect to mg2922 printer
My MacBook Pro is connected to my wifi network and I can print directly to the MG2922. However, I cannot connect my iPhone nor iPad to the printer. I am using OS 15.2.1. I have also downloaded and tried using the Canon App. I get the error message "N...
Imageclass D1120 Scanner not found
I have a D1120 connected via Ethernet. The printer works fine, and the scanner used to ... that is, I used to be able to scan to the PC using the MF Toolbox or Windows Fax and Scan utility. Now, in both cases, the scanner is not found. The Toolbox yi...
rdhull50 by Apprentice
  • 2572 Views
  • 2 replies
