scan issue with monterey 12.3 & mx925
I have a mac running monterey 12.3.1 and a MX925 printer scanner.I can print but not scan is there a new driver to download or is it another issue - TIA
I am not able to connect my new printer to my WIFI system and laptop.Following the instructions I get stymied when I am looking for the ICON which looks like a DISK with a down arrow going thru it. My dashboard has nothing like that.I am using WINDOW...
IJ option not available for Canon PRO-1000 on M1 Max Monterey PowerbookNOTE: I have installed the latest print drivers from the canon website, deleted my printer from the "Printers and scanners" in the System Preferences.When adding my Canon PRO-1000...
Because my printer works sporadically, I often uninstall and reinstall the printer. When I tried to do that this time, there is no printer listed to add. I then look it up by IP address and nothing happens.
Get following on bootup: There was a problem starting C:\Users\Rocky\cnmss. The specified module could not be found. I am using a Canon MG5500/5220. Am very frustrated with this issue as I have tried numerous recommended fixes from online resources...
We just got a new modem and after that we learned our printers were unable to connect to the network. We bought a new one thinking that would solve it but it didn't. In settings when we select the modem it bypasses the password entry screen and tells...
I have a Canon PIXMA G7020, it works fine from my W10 Laptop. But on my W11 laptop I have a problem. When install the Canon Software I get a message "An error occurred while files were being copied" When I click on the IJ Scanner Utility I get an er...
Hello, I've had issues printing from my computer and my phone. I tried to delete the printer and add it back now the system is saying the app is out of date and I need to ask the developer to update the app. I see the printer in my settings but it al...
When I first got this printer I did the easy setup by simply pressing and holding the wireless button on the printer to get it into WPS mode and pressing the WPS button on my Netgear AP to get it to connect. From there I had it up and running fine on...
Does anyone know if the Canon Office Printer Utility can be downloaded manually to a Windows 10/11 PC? It's available from the Microsoft Store, but my company blocks access to the MS Store. I can't print to my Imageclass LBP622CDW (usb) without this ...
I recently purchased the TS9120 and connected it wirelessly to my iMac 27" Retina running MacOS Mojave. I can print without a problem to it, but neither the scanner nor the Mac see each other (for scanner functionality). After downloading the IJ Scan...
Hello, I have a MacBook, running macOS Mohave. Originally I did have the printer connected wirelessly but recently my roommate took it upon himself to move and change the router. I can connect everything else to the internet except the printer now....
I received a PIXMA MX330 printer as a gift from my pastor. It is used, but he said it still worked, but he was unable to find the disc that it came with. Is there a way to get a replacement disc so I can connect it to my computer? I have tried downlo...
Just bought a new ImageCLASS printer (LBP6230DW) and have spent hours trying to get drivers for my OS. The Canon download page doesn't recognize my OS, the configuration app on the CD says the driver can't be installed on my OS. Twenty years ago I wo...
| Subject | Author | Posted |
| 09-15-2026 07:21 PM | ||
| 09-13-2026 07:01 PM | ||
| 09-10-2026 02:37 PM | ||
| 08-14-2026 05:48 PM | ||
| 04-28-2026 08:20 AM |
