10-13-2021
04:40 PM
10:01 AM
Mac Big Sur 11.6
I've installed the latest version of Canon Print Studio Pro to use with Photoshop Elements 2021. When I select Automation Tools under the "File" tab, Canon Print Studio Pro is an option. When I select it PSE completely freezes. The only way out is a Force Quit. Any help will be appreciated.
Thanks
10-27-2021 04:09 PM - edited 10-27-2021 04:11 PM
Hello Jrl46,
10-13-2021 07:44 PM
Sounds like an integration problem between the tow apps. Does Print Studio Pro work on its own, all by itself?
10-14-2021 07:40 AM
This is a known problem with macOS 11.6 and PSP. No fix at the moment.
10-14-2021 07:41 AM
@Waddizzle wrote:Sounds like an integration problem between the tow apps. Does Print Studio Pro work on its own, all by itself?
PSP is not a standaolne product. Plugin only to limited software.
10-14-2021 07:42 AM
Thanks for your reply. I didn't realize Print Studio Pro could be used as a stand alone program. Thought it was just a plug-in. Not sure how to run it on it's own.
Hello Jrl46,
10-27-2021 05:58 PM
Thanks for your response.
Yesterday I upgraded to 11.6.1, reloaded PSP and it worked fine for a bit. But now when I select Print Studio Pro from the Automation menu in Photoshop Elements 2021, PSP starts to load then I get a popup that says "An Error Has Occurred" "Exiting Print Studio Pro". The only choice is to hit the "OK" button and that causes PSP to close. Any help or advice will be appreciated.
10-27-2021 07:47 PM
I don't hav PSE but it does work OK for me with Monterey and PS 2022.
Maybe try reinstalling the plugin.
12-14-2021 05:32 PM
Mac OS 10.14.6, will upgrade to Monterey (OS 12). Currently Print Studio Pro (PSP) is version 2.2.3 as a plugin to LR Classic 10.4. Does a simple install of version 2.2.5 automatically update/replace version 2.2.3, or should version 2.2.3 be uninstalled first? Currently I cannot update to the latest of LR Classic and PS, hence the need to upgrade the OS to Monterey.
01-11-2022 12:14 PM
I use Lightroom Classic with PSP (2.2.3), currently use Mac OS 10.14 (Mojave) and will upgrade to Monterey (12.1) on Intel iMac 2017. Are there any issues with 2.2.5 working as plugin for LR Classic (latest version) in Mac OS 12.1? Yes, I read the issues with Big Sur were resolved, but no reliable information for Monterey.
