02-28-2024 09:40 PM - last edited on 02-29-2024 12:25 PM by Kristoff
First -
I am shocked at how bad the Canon software, process and instructions are (and I am a software engineer who has a sympathy for designing such things) ... but maaaaaaaaaan Canon - this is embarrassingly bad.
Printing, and scanning - for several years - with this setup. Just printed something, no problem,. Then tried to scan (something I do fairly often).
Not recognizing scanner. You recognize the printer but not the scannner. um ok - that's where the fun begins.
Nothing was changed with my setup, Tried everything. Then went to your troublesooting site.
Getting out the thesaurus: Useless. Lazy. Worthless. The last refuge of incompetent software design: tell the customer to uninstall and reinstall. Done it.
Now ... I can't print, scan or even connect. Ironically your setup process is stuck on "Easy Connect' (despite my manually entering the wifi settings).
And that's all she wrote.
I can't return this piece of junk. But by chance - do you offer an coupons for HP Printers?
Shame on you Canon.
Using Windows 11 Homw
02-29-2024 09:26 AM - edited 02-29-2024 09:26 AM
Thanks for joining the conversation, cjcornell!
So that the Community can help you better, we need to know exactly which Canon printer model you're using within the PIXMA TR4500 series. The model number should appear on the front of the printer at the upper right. We also need to know exactly which operating system is running on your computer (i.e. Windows or macOS, and which version thereof). That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
02-29-2024 12:15 PM
Canon Pixma TR4520
Windows 11 Home Build 22621.3155
Printer and scanner has been working (via wifi network) reliably for 2-3 years.
Then - scanner no longer shows up in list nor works. Your troubleshooting tells me to reinstall the drivers -- I did ... then the printer no longer works (or is not recognized) ... after 5 attempts, reboots etc .. I finally got the drivers to install again and recognize the printer. But the scanner does not show up in any lists .... or is recognized.
05-09-2024 04:41 PM
Same problem. Getting to the answer was crazy! But, here's what worked for me:
Go to Start menu, then All Apps, then Canon Utilities, then IJ Scan Utility. You can scan from one of the boxes on that screen! Who knew! (Apparently the Scan button on the printer control panel will not work.
05-09-2024 04:41 PM
