01-22-2026 01:47 AM
Hi, been working on this problem for days now,I am on the same Wi-Fi network, printer, Android and laptop, the printer IP address not found by laptop, Android, and Canon print service. on Android printing page on screen, C-P Service showing a different IP address than the printer , I uninstall addgard , deactivated firewall but still can not reach the printer IP address from a web browser, tried to ping, not working. HELP if you can, I know it's an old printer. Thanks
01-22-2026 09:49 PM
Hi thanks, my house is fully AI, connected so I need allot of IP address but, don't think I need 1022. This Primus guest 2.4g is a must because I will not connect with my 5g to this printer . This guest network was working fine before. i just figure out something while reading your text, I have not a router modem combo, I just see my router in front of me but I forgot that the modem is hidden under a table, so I will perform a proper shut down, and let you know if that changes anything. Because in my shut downs I only shut the router not the modem. Thanks again
01-23-2026 05:03 AM
Restarting that device is unlikely to solve your problem. I suppose you can try. Is the modem configured for pass-through mode? If both devices are configured to perform DHCP, a double nat situation will exist.
01-23-2026 10:53 AM
Hi thanks, you are right it would not give me any other positive results, so I'm left with no answer. It must be something blocking somewhere. Can't I just tell my router to use or let pass this IP address? I know for sure the DHCP gave this address to the printer , but it's being block somewhere like I said.
01-23-2026 11:58 AM - edited 01-23-2026 12:03 PM
I think you are onto the problem Rick. My house mesh does the same thing, isolates all devices from each other while allowing internet access. This is the primary purpose of a guest network is it not? If you are correct, then the solution could be as simple as accessing the printer's control panel and searching for the primary network and adding the printer to it.
Access the Printer Menu:
Menu button on the printer.Select Wireless LAN Setup:
Wireless LAN Setup and press OK.Choose Easy Setup:
Easy Setup and press OK. The printer will search for available networks.Select Your Network:
OK.Enter the Password:
OK to confirm.Complete the Setup:
Install Printer Drivers:
Add the Printer to Your Computer:
Devices and Printers on your computer.Add a printer and follow the prompts to add your Canon PIXMA MX340.01-23-2026 12:43 PM
Hi thanks, I tried troubleshooting the printer with win 11, and this came out 504 the service behind this page is not responding to azure front door. It can not connect to the origin server,. I'm really confused by all this. Thanks for your help
