MX340 -win11- Canon print service not finding printer
jo6
Hi, been working on this problem for days now,I am on the same Wi-Fi network, printer, Android and laptop,  the printer IP address not found by laptop, Android, and Canon print service. on Android  printing page on screen, C-P Service showing a different IP address than the printer , I uninstall addgard , deactivated firewall but still can not reach the printer IP address from a web browser, tried to ping, not working. HELP if you can, I know it's an old printer. Thanks
14 REPLIES 14
Anonymous
Not applicable
Is your WIFI set for 2.4ghz? Canon printers will not connect to 5ghz WIFI.
Forgot to mention that, yes it is on 2.4, like the screenshot shows, this cp service ip is different than the printer IP for Android, on my phone, but I also can not reach it with win 11 ,I am block somewhere, tried to ping, tried a web, can not reach ip  printer, I made files and printer sharing available, but no result. Thanks for your help
We're going to need some additional information to try to help you resolve this.
Please tell us about your networking hardware.
Modem, router..  or modem/router combo?  Are you using a mesh system?  Is this hardware issued by your ISP or something you put together?  Please be as descriptive as possible. I'd like to understand why the IP you think the printer has is different than what may be shown elsewhere.
Do you have any third party antivirus installed, or software firewall that might be blocking network communication?
Are you using VPN On the laptop or mobile device?
Please login to your router's admin portal and review the list of attached devices.
What does it show for the IP address assigned to the printer?
What IP does it show for the computer?
And the IP for your mobile device is?
When you refer to C-P.. Are you referring to the Canon print app?
We are not going to be able to move forward until we understand why you can't ping the printer from the laptop.
Hi, yes it's a combo, from my Internet provider. I checked the printer IP provided by DHCP and it's the same in my modem router, no problem for that. It's only on the screenshot Canon print service page provided that the IP is different my printer IP is; 192.168.. 68.77 and on the screen shot of cps it's different, I don't know if it's normal? because the cps can't reach the IP printer,  or it's stock on 192.168.68.68 , maybe it changes when it's reaching the right printer IP, I don't know that. But what I know is that I can not also reach the printer IP from my laptop and last time, 2 weeks ago I could. Something is blocking me. It must be the firewall but where??? In the firewall. Yes I'm using add blockers on Android and win 11 but I tried to ping the IP printer with both blockers off, no success. Yes CPS is for Canon print service. Maybe the add blockers changed something in my firewall?. Thanks for your help
Hi thanks here's a screenshot of the ping
Thank you.
So in the list of attached devices on the router, the..
Printer's IP is 192.168.68.77
Your computer's IP is? (you didn't state)
You can also use >ipconfig /all from a command prompt 😉 which would let me see the IP address, subnet mask and gateway
Your Phone's IP is? (you didn't state)
For now, don't worry about the Canon Print App.  I'll make further determination on compatibility once we get some additional information.
I'm curious.  Is your laptop running windows 11 24H2 for ARM.  Does it have a Snapdragon processor?
If unsure, click the start button > Setting cog, System > About.  Is it Intel , AMD or ARM?  The build number on your command prompt has me wondering.
I think we are closing in.  😉
Hi thanks, my computer IP and the rest in the screenshot on here, phone Android ip192.168.68.69. processor AMD a6-6310 APU with Radeon r4 graphics. No Snapdragon.. Really appreciate your help. Thanks
jo6
This is the printer network configuration page in screenshot
You've giving me bits and pieces, but they are helpful 🙂  Do you really need a CIDR /22 and 1022 IP's on your home network?
Address:   192.168.68.1          11000000.10101000.010001 00.00000001
Netmask: 255.255.252.0 = 22 11111111.11111111.111111 00.00000000
Wildcard: 0.0.3.255 00000000.00000000.000000 11.11111111
=> Network: 192.168.68.0/22 11000000.10101000.010001 00.00000000 (Class C)
Broadcast: 192.168.71.255 11000000.10101000.010001 11.11111111
HostMin: 192.168.68.1 11000000.10101000.010001 00.00000001
HostMax: 192.168.71.254 11000000.10101000.010001 11.11111110
Hosts/Net: 1022 (Private Internet)
 I noticed your SSID name is Primus_65674_Guest
If this is a guest network, its likely device isolation is keeping devices from communicating and seeing one another.  It doesn't matter if the devices are on the same network.  This is typical of guest networks.  Might this be the problem?
