PIXMA MG3620 Drivers: Specified Pathway Is Too Long Error
tstrutton
I am getting an error message that the specified pathname is too long for the MP drivers.  How can I get around this?  I am using an HP laptop running Windows 11, and trying to install Canon MG3620.  I tried to install via wireless installation but my laptop was not able to locate the printer, so I tried again with a USB cable which seemed to be working but then I got the aforementioned error message.  I can't find where to make changes to resolve the problem.
There was a previous post about this but there was no description as to how the problem was resolved.
Thanks.
ncdblue
I think I have I dentified the issue.
the problem is the location of the installer files using the download and run feature it runs from a temp folder buried down under your user account folder. The CD drive install is just 1 level down from the drive letter.
To work around the issue, download the file and move it to a top level folder (EG. C:\My_Temp\<download name>) and run it from there. once the install has been completed, you can delete everything in that folder (except the original download if you want to keep it)
6 REPLIES 6
bluedeviltrish
I am having the same problem.  Did you find a work around?
tstrutton
I did finally get the software installed, but I can't really say how I managed to do that.  I did actually purchase an external CD/DVD reader and used the CD that came with the printer, so maybe that was it.  I also clicked on the option to get software off the first page instead of going the route of downloading that I'd been using chose "My Printer" off the drop down list.  I think that may have been what worked, but not sure.  No one ever responded to my request for assistance though.
Jayhawk89
On multiple tries, I received the same message window: "The specified pathname is too long. Change the pathname to within 180 characters".
Before I resorted to trying to use the CD that came with the printer, I tried one last time with a different step. On the Canon web site setup screen, click on the big orange download button. During the download, it will give you the option of opening the file or saving it. Instead of opening the file, I chose to save it to my C:/temp folder on my hard drive. I then clicked on the saved file (win-mg3600-1_1-n_jucd.exe) and it launched the Start Setup window. This time, the printer setup proceeded successfully without the error message. I'm not sure why the save to drive option solved the problem, but this is what worked for me.
DerrickL
Whiz
Whiz
Sometimes Windows installations can mess up due to a slower download speed than the files being installed, this will cause an error. Saving the complete download and then running it prevents this mismatch.
ncdblue
^^ is a solution.  Would a Moderator please mark it as such?  The installer has enforced a 180-character path limit and the default installation path exceeds this limit, and this is a valid and workable workaround.
Plus>> Canon imagePROGRAF PRO-1100 Printer
