08-03-2015 04:18 PM
I have a MF4570dn, and recently upgraded from Windows 8.1 to Windows 10.
I can no longer scan using the MF Toolbox utility. I had MF Toolbox 4.9 installed before the upgrade, and it worked just fine. After the upgrade, I get "Cannot communicate with the scanner" error dialog:
I thought I would try to reinstall the MF Toolbox utility, but there are two problems.
1) The downloads page shows no downloads for Windows 10 for this printer. This should be updated.
2) I downloaded the one for Windows 8.1, and tried to reinstall, but it just hangs at the "Processing Installation" screen:
I've also tried to uninstall the existing MF Toolbox first, and it also hangs at this same dialog.
I've also tried various other things without success:
- Connecting via USB instead of Network. It detects the scanner, and MF Toolbox can switch to that device, but it still gives a communications error.
- Trying the built-in Windows Scan app instead of MF Toolbox. It uses the WIA driver. It barely starts to scan, then immediately cancels.
Please Canon - forward this to your engineers and provide a fix asap. I cannot use my scanner on Windows 10.
(I can use the printer functionality just fine.)
10-05-2015 04:45 PM
Thanks. My model's links are different, but the new software appears to work.
Also, to get the old toolbox uninstalled, I had to reboot into safe mode. Otherwise the uninstaller just hung. Then booted back into regular mode, removed all traces of the existing printer, then reinstalled the new software and it works great.
08-04-2015 04:55 AM
08-04-2015 08:35 AM
I have the same problem. I can print, but cannot scan now that I have Windows 10.
08-04-2015 01:42 PM
I upgraded to Win 10 on six machines. five machines can print. One can not load the driver and can not print.
No machine can scan.
I hope this gets fixed rapidly. I really need the scanner.
08-25-2015
04:23 PM
04:28 PM
Ok here's the fix..I tried many of the ways, from compatibility mode to deleting twain and here's the right way.. it just requires a few reboots.
I use revouninstaller to uninstall programs. I paid for it but there is a free version...
[link removed per forum guidelines]
With Revo
uninstall drivers ( then do an advanced scan and remove any entries anywhere for cannon toolboox and mf drivers. Very easy to do with Revounistaller.
Uninstall mf toolbiox..advanced scan again remove all entries to mftoolbox Again very easy with revo.
Reboot
install window 10 Cannon drivers for your machine (printer scanner)
Install mftoolbox...
Reboot
Start scanning
PS if by chance you messed up and the uninstall states that the program must be installed to uninstall again do a forced uninstall with revo. Do not leave any traces of the old mftool box and / or drivers. Revo will do that for you.
08-25-2015 11:47 PM
03-14-2019 12:08 PM
The first time I installed the scanner and printer drivers I had no problem. Reinstalling a year later would not allow NETWORK Scanning. The Canon Scan tools would not load, but the printer worked wirelessly
I found this Scanner-only version at Canon Malaysia that installed (not available on Canon USA). So now I can use my network scanner again
https://support-my.canon-asia.com/contents/MY/EN/0200450804.html
08-04-2015 03:51 PM
Same here. Please fix this soon Canon!!!!!
08-05-2015 08:15 AM
I Upgraded to Win 10 today, so I had this problem too.....however......
OK, so this isn't an exact substitute for the Toolbox....I have an MF4770n.
I did find Win 10 Drivers on this site, so maybe they are new additions.
Download and install the latest drivers for your MF4770n from this site. Restart your PC. Test printing.
Then go to the Windows App store, search "scan", find "Windows Scan" app, install.
At MF4770n load a doc to scan, select Remote Scanner,
At the PC, open Windows Scan App - it found the 4770n instantly on my system.
Use the drop down menus to select source, output etc. You can preview platen scans, not auto feeder docs.
Doc feeder worked to scan a 5 page PDF first try!
Works for me, hope it does for you.
Steve
08-05-2015 09:11 AM - edited 08-05-2015 09:12 AM
BTW: The driver for Win 10 x64 is
MF4700_Series_MFDrivers_W64_us_EN_2.exe v20.90
for my Canon, I hope there is one for all of you!
