03-25-2026
09:51 AM
09:56 AM
Hello. TR8620a connected to MacBook Air running macOS Tahoe 26.3.1.
When I try to scan from computer using IJ Scan Utility Lite I get the following error message:
When I select the Instructions button the following page appears:
The only error message that appears in the Instructions popup is 244. As shown I have authorized full disk access.
Scanner works fine with VueScan so it is not likely an installation or connectivity issue. I did re-install printer just before this scan attempt.
03-26-2026 03:26 PM
Yes. Followed those steps - no resolution.
But, I just updated to macOS 26.4 and problem is resolved.
Thanks for checking in.
03-26-2026 01:11 PM
I take it you did the following:
To resolve the folder access privilege error in IJ Scan Utility Lite on your MacBook Air, follow these steps:
If the issue continues after checking permissions, you may need to grant full disk access to the IJ Scan Utility Lite or Preview app:
03-26-2026 03:26 PM
06-06-2026 11:49 AM
I also have this problem, and have for some time. Today I updated my OS to Tahoe 26.5, and download the new driver for the Scanlite Utility for my G7020. I also followed all the instructions as above, granting the Utility (and Preview, as suggested) all disk access. This did not fix the issue for me. Any help would be appreciated.
06-06-2026 01:20 PM
I get the error when I select Auto but not when I select a specific task like Photo or Document.
06-09-2026 10:10 AM
I get the error when I select ANY of the options. The only way I can scan is through my computers utility. Not as many options, but at least it works.
