IJ Scan Utility Lite folder access privilege error
jrhoffman75
Hello. TR8620a connected to MacBook Air running macOS Tahoe 26.3.1.
When I try to scan from computer using IJ Scan Utility Lite I get the following error message:
Screen Shot 2026-03-25 at 09.41.40 AM.pngScreen Shot 2026-03-25 at 09.41.40 AM.png
When I select the Instructions button the following page appears:
Screen Shot 2026-03-25 at 09.42.47 AM.pngScreen Shot 2026-03-25 at 09.42.47 AM.png
The only error message that appears in the Instructions popup is 244. As shown I have authorized full disk access.
Scanner works fine with VueScan so it is not likely an installation or connectivity issue. I did re-install printer just before this scan attempt.
Yes. Followed those steps - no resolution.
But, I just updated to macOS 26.4 and problem is resolved.
Thanks for checking in.
7 REPLIES 7
DerrickL
I take it you did the following:
Fixing Folder Access Privilege Error in IJ Scan Utility Lite
To resolve the folder access privilege error in IJ Scan Utility Lite on your MacBook Air, follow these steps:
Check Folder Permissions
  1. Right-click on the folder where you want to save your scans.
  2. Select "Get Info."
  3. Ensure that your user account has write access. If not, adjust the permissions accordingly.
Grant Full Disk Access
If the issue continues after checking permissions, you may need to grant full disk access to the IJ Scan Utility Lite or Preview app:
  1. Open System Settings.
  2. Navigate to Privacy & Security.
  3. Find Files & Folders and check if IJ Scan Utility Lite or Preview is listed.
  4. If not, go to Full Disk Access and add the app to the list.
I also have this problem, and have for some time. Today I updated my OS to Tahoe 26.5, and download the new driver for the Scanlite Utility for my G7020. I also followed all the instructions as above, granting the Utility (and Preview, as suggested) all disk access. This did not fix the issue for me. Any help would be appreciated.
I get the error when I select Auto but not when I select a specific task like Photo or Document.
I get the error when I select ANY of the options. The only way I can scan is through my computers utility. Not as many options, but at least it works.
Hi Betty Knutson,
To resolve the scanning issue you are experiencing , please follow these steps:
1.  On your Mac, please create a new folder on your Desktop and name that folder Scans.
2.  After the folder is created, please open the IJ Scan Utility.
3.  In the IJ Scan Utility, please click the Settings button.
4.  In Settings, please click on "Document Scan" on the left side.
5.  On the right side, please click the "Save In" drop down box.  Browse to your Desktop and select the Scans folder that you had just created.  Once Scans is selected in the Save In box, please click OK.
6.  Back in the IJ Scan Utility please click the Document button to perform a scan.
You may repeat this process for each button that you wish to use, ex: Auto Scan, Photo Scan, etc.
BettyKnutson
ACCEPT AS SOLUTION! This did work for me. Thank you Patrick.
