12-05-2021 11:01 AM
I just received my new PRO-300. I went through the installation process, selected the Canon PRO-300 Bonjour in the driver interface, and then "Canon PRO-300 Series" from the drop-down menu.
But when I look at the printer in "Printers & Scanners", the name of the driver installed is "Canon PRO-300 Series-Airprint". Does that mean I installed the AirPrint version? I know I'm not supposed to do that. My Canon PRO-100 printer shows "Canon PRO-100 Series", and doesn't include "AirPrint".
12-05-2021 12:17 PM
I found instructions for completely removing and resintalling the driver, and that did the trick.
12-05-2021 11:50 AM
A little more info. When I click on "Options and Supplies", this is what I see:
This makes me think the driver is installed correctly, because it shows the Canon PRO-300 Series driver 3.0.
But when I go to print, I don't see all of the options that I think I'm supposed to see for the Canon PRO-300:
For example, there is no "Color Options" choice where I would configure settings for B&W printing.
What am I doing wrong?
12-05-2021 12:17 PM
12-05-2021 02:49 PM
Yes, you have the AirPrint version that you do not want. Repeat the add process and for the Canon IJ Series driver to appear. It could take several minutes. Then delete the AirPrint version.
01-03-2024 02:52 PM
For anyone still encountering this issue, it can be a bit confusing as some of the nomenclature has changed somewhat with current canon IJ setup and installation. Long story short, it is entirely possible to wind up with the airprint driver installed instead of the cups driver (which is what you want to avoid many issues and have complete control over printing, with correct borders and margins, even when using Canon's Professional Print & Layout app).
So, if you are experiencing uneven margins, undesired borders on two edges, and other similar issues...
Firstly, go to the Canon support download, which for the pro-300 is here -> https://www.usa.canon.com/support/p/imageprograf-pro-300
Download the driver named "PRO-300 CUPS Printer Driver Ver.26.10.0.0 (Mac) "
Versions will change over time but the point is you need the CUPS driver, not the airprint driver.
Install it, and add a new printer as jrhoffman explains above then remove the old one when you've confirmed it has the correct driver by inspecting the printer settings under Printers & Scanners. If it still says airprint you haven't fixed the issue.
What is currently as of this writing confusing is there is no distinction made in the install printer dialog windows, between the two drivers, both simply display as "Canon PRO-300 series" and the specific version isn't visible until you inspect the settings on an installed printer on MacOS.
Of course the big tipoff is the missing advanced and detailed settings in the print dialog, as well, when printing directly from the driver via the OS print dialog, or from within Lightroom when opening printer settings (see attached, which is what you will get with the proper driver installed).
01-03-2024 02:58 PM
As Mr. Grant says there is no way ahead of time to determine which driver is showing up. Usually the AirPrint driver appears first, so waiting until a second driver appears and selecting that will generally give the Canon driver.
12-17-2024 08:48 AM
I've spent several days trying to solve this so thank you so much for this post, it has only just in time prevented me from exiting the printer through the office window! I'm sure it's not possible to devise a more complicated, confusing software/firmware install procedure but I could be wrong!
