imageCLASS MF753Cdw Scanner Driver Won't Install
jbrand0
Using windows 11 home and have the MF753cdw printer/fax/scanner. I have no issues installing the printer and fax drivers but cannot get the scanner driver to install. I have tried turning of the firewall to install and no luck. Depending on how I get to the driver I get an error that just says install failed or I get an error that says install error due to port error. I have also tried to connect via usb cord and wi-fi.
1 REPLY 1
elc
I'm having the exact same problem, only on Windows 10 Pro.  I've even tried logging on as the domain admin and the darned scanner driver will NOT install.
