05-19-2016 06:51 PM
OS: Windows 10
Wireless internet
Canon PIXMA MG3620
I only purchased it as a scanner, and do not have it set up to print. It's been working for a few months, but sometimes it stops connecting to the wireless for no reason. Usually rebooting my PC, or the scanner will fix this.
This time it won't and I don't know what to do.
I've rebooted my computer and tried multiple times to pair my scanner with the wireless, but it doesn't seem to be properly connecting to my PC.
I get the error "Cannot communicate with scanner for these reasons:
-scanner is turned off.
-If using LAN connection, it is disconnected from LAN
(etc, etc)
Code:5,157,69
On the top of the scanner the Power button is lit (green), the wifi button is lit (blue) and the 8.5"x11" plain paper button is lit (green).
What do I need to do to get the scanner and computer connected again?
10-06-2018 10:01 AM
Priyanka,
Make sure that your computer is connected to the same SSID as the printer. If the error persists, try uninstalling and reinstalling the drivers to see if this will allow the unit to communicate again.
If the issue persists, troubleshooting with our support group will be needed to narrow down the cause of your issue. Please contact our support group using the "Contact Us" link below for additional assistance.
10-23-2018 08:03 PM
I have an MG3600 series and I am having the same problem. I have followed all the steps with both using the color button and black button to try and setup the wireless. When I do the network test it says Infastructure Enable, Connection Inacvtive, SSID BJNPSETUP, Channel Blank, Encryptyion none, WEP Key Length Inactive, Authentication open. PLease help this is super annoying I have already wasted 2 hours trying to set this up in 10 different ways.
10-25-2018 02:30 PM
I cannot get my new canon mg3620 to connect to my laptop. I have printed out the network configuration page as was recommended in a previous question and this is what I have.
Connection - inactive
SSID - BJNPSETUP (I do not recognize this)
IP address is blank
10-26-2018 05:22 PM
Hi hoodsiecup,
The BJNPSETUP SSID indicates that the printer is ready to be connected to a wireless network, but has not done so yet. The PIXMA MG3620 can be connected to a network a few different ways, so if one method is unsuccessful, another can be used. I have included instructions for those methods HERE.
This didn't answer your question or issue? Please call or email us at one of the methods on the Contact Us page for further assistance.
12-08-2018 04:25 PM
Discription:
When I just got my printer, it was able to connected to my devices smoothly. But after I moved it to a new spot in the same room, it loses the connection with all my devices. I've attempted countless times try to reconnect it with my tablet, PC, and iPhone but never succeed.
The problem:
The printer can be found by the software "Canon IJ Online Master Setup" by "press and hold signal button, then press black/colour button, then press signal button". It has the serial number and MAC address, but no IP address. If I click next step, it will say "the connection is complete" and the power button and signla button start to blinking at the same time.
I click "nect step" the installation suddenly stopped, the software start to searching for the printer on network. At this point, the alarm lamp lighted up without any blink, the signal button start to blinking twice a time.
Network Configuration Page:
Product Information
Product name MG3600 series (my machine is MG3620)
ROM Version 2.050
Serial Number (Classified)
Wireless LAN Enable
MAC Address (Classified)
WPS PIN CODE (Classified)
Infrastructure Enable
Connection Inactive
SSID (my home WIFI name)
Channel (blank)
Encryption none
Authentication auto
Signal Strength 0% (before was 67% at the same spot)
TCP/IPv4 Enable
IP Address (blank)
Subnet Mask (blank)
Default Gateway (blank)
TCP/IPv6 Enable
IP Address (blank)
Subnet Prefix Length (blank)
IPsec Inactive
Security Protocol (blank)
Access Point Mode Disable
Connection (blank)
SSID (blank)
Password (blank)
Channel (blank)
Encryption (blank)
Authentication (blank)
TCP/IPv4 (blank)
IP Address (blank)
Subnet Mask (blank)
TCP/IPv6 (blank)
IP Address (blank)
IPsec Inactive
12-08-2018 04:27 PM - edited 12-08-2018 04:44 PM
If you go back to the old spot does it work?
12-08-2018 04:40 PM
I am positive it is not the main issue in my situation
12-08-2018 04:47 PM
So you are saying that the signal is now 0% and it doesn’t matter what position?
Sounds like Ike something happened to your WiFi router?
12-08-2018 04:48 PM
It had 67% Signal strength on the same spot before
12-08-2018 04:49 PM
and all my other devices are connected to this WIFI without issue
