Canon PIXMA MG3620 Won't connect Wirelessly to PC
rainedragon
OS: Windows 10
Wireless internet
Canon PIXMA MG3620
I only purchased it as a scanner, and do not have it set up to print. It's been working for a few months, but sometimes it stops connecting to the wireless for no reason. Usually rebooting my PC, or the scanner will fix this.
This time it won't and I don't know what to do.
I've rebooted my computer and tried multiple times to pair my scanner with the wireless, but it doesn't seem to be properly connecting to my PC.
I get the error "Cannot communicate with scanner for these reasons:
-scanner is turned off.
-If using LAN connection, it is disconnected from LAN
(etc, etc)
Code:5,157,69
On the top of the scanner the Power button is lit (green), the wifi button is lit (blue) and the 8.5"x11" plain paper button is lit (green).
What do I need to do to get the scanner and computer connected again?
51 REPLIES 51
Hey 2020er! I am getting severely frustrated because no matter how long I hold the wifi button, none of the other buttons blink! Any advice would be amazing!
Hi Stacy,
Not sure if you would see this reply as your post was old. But I'd like to you thank you because my printer is now connected with the network after I followed your notes. I've spent hours yesterday, invain. The key word is "Immediately". Not sure how you figured that out, but you're great! Thank you!
BenD
Hi, Connection is inactive, SSID is correct, signal strength 0, IPv4IP says enable. Any advice? Thanks so much!
The Infrastructure connection reads INACTIVE.I don't know how to make it active. The SSID reads one of the addresses I have correctly. Ther Signal Strength reads 0 [%]. TCP/IPvP reads Enable.
Access Pint Mode reads Disable
Did you ever receive a response to your question?  Mine is the same, I'm just wondering.
Thanks!
Hi Senebo,
No I have not received any response, I didn't expect any. The instructions provided are correct, it's just that you'll need to do it  fast enough.  Look for the post Stacy made on page 2 of this thread.
AmberCxx
I had the same trouble, tried several solutions: reset, restart router, connect to printer manually, using app in iphone, etc. The answer on page one, regarding a installation of a pc app works. https://ugp01.c-ij.com/ij/webmanual/WebPortal/PTL/ptl-setup.html?lng=en&type=setup&area=ca&mdl=MG362...
( although i have to work around it. it could not found the printer initially...
I need help with connecting my WiFi to my printer or connecting my printer to my WiFi. I followed these steps and here are my answers:
1. Inactive
2. Yes
3. 0%
4. I'm not sure what's the answer for this, so I'm just gonna list whatever I see with "IPv4".
This is all the paper says:
"TCP/IPv4 Enable
IP Address
Subnet Mask
Default Giveaway
Please tell me how this will help me.
Hi M_Salas671,
Go to page 2 of this thread and check the notes posted by Stacy on ‎07-23-2017 12:32 AM.
yes everything is right
Holiday
