03-03-2025
08:21 PM
09:44 AM
All,
I have upgraded to a new 2024 Mac desktop computer with MacOS Sequoia 15.3.1 operating system. I have an older Canon Pixma MG3620 printer/scanner..... It worked beautifully with my old Mac (High Sierra 10.something).... but I can't get the scanner device to operate now. I went to the Scanner Driver section of Canon's website and downloaded the latest version for the Printer/Scanner driver update. But it still won't work--I get the message "Failed to open a connection to the device (-21345)." What gives folks? --JimCasey
03-03-2025 09:32 PM
Did you install the ICA driver?
03-03-2025 09:32 PM
03-05-2025 05:21 AM
Hello Rick!
Whoever you are, you truly are an Illuminary!! Your one little Reply to my desperate message has saved me so much frustration and anxiety (not to mention money!) I followed your link and downloaded your ICA Driver for MAC OS 15 and installed it--it worked PERFECTLY! I didn't even have to restart the Mac! What a Godsend! Thank you so much for reaching out and providing me with a solution that works! If you don't already work for Canon or Apple or Adobe, you should!! Genius Bar kids, take note!
I was so sure I would have to buy a new Canon printer for about $70 or more! I just spent a small fortune on buying my new Mac with accessories--I can't afford much more! I love my little Canon powerhouse IJ printer/scanner! I scan a lot of B&W documents for emailing business purposes, so now I am back in business! Rick, thank you again, very much! You are great--a true Gem among Gemstones!
Sincerely, Jim Casey, Chicago, IL
03-19-2025 05:58 PM
Thank you both! I was about to throw in the towel when I came across your reply. 30 sec/DONE! Why couldn't the
Thank you both! After 45 min of scouring for conversion to 32 bit for MAC I found the response from Shadowsport. 30 sec --done and done. Why doesn't Canon use the words 32 bit somewhere? Who the heck knows what an ICA Driver is? Thanks you Jim and Rick!!!
Annie
03-19-2025 08:23 PM
Greetings worldgirl,
I appreciate your feedback. Jim, you also. 🙂
03-24-2025 05:08 PM
Will this work with my Pixma MG6150 as well. I have exactly the same problem as described by JimCasey and the Canon Support team tells me that there is no solution and that i should buy a new printer:-(
Where is this driver coming from? Is there an official download page?
