Printing unwanted color vertical lines on page
FiremanPete
My mf731cdw prints color vertical lines, primarily blu and yellow. I have cleaned the fixing assembly and the ITB. Same.
Darius
Whiz
Hi FiremanPete.
On the Auto-adjust sheet (<Adjustment/Maintenance>  <Adjust Image Quality>  <Auto Adjust Gradation>), do blank vertical lines appear through any of the colored bars printed?  If so, those respective toner cartridges may be faulty or damaged; if they're within the toner cartridge warranty, you'll want to call our support for help replacing them.  If not, then you'll want to contact our phone-based support for assistance correcting the lines that appear.
Our support is available at 1-800-OK-CANON (1-800-652-2666) Monday-Friday from 10:00 am to 6:30 pm ET, excluding holidays.
4 REPLIES 4
Darius
Whiz
Hi FiremanPete.
I'm having this same problem.  The color lines are down the right side of the page.  They come and go but are mostly there.  I did a maintenance cleaning a couple of times and they disappeared but soon returned.  I followed your instructions above but I see no blank lines running through the color printed.  Just the color lines that don't belong on the right side.
Hi Pennyrub,
If the problem disappears after the cleaning and returns, the issue can be the paper or toner cartridges. Try new pack of paper. Replace the genuine toner cartridges, if the issue continues.
You can also find suggests in the online manual at:
https://oip.manual.canon/USRMA-1738-zz-SS-enUS/contents/SS735_troubleshooting_0259.html#1108_h2_07
If you continue to have difficulties, please contact our support group using the following link:
http://Canon.us/ContactLI
Thank you for the help.
Lesson learned here today, in an effort to save money I purchased copycat toner cartridges. Turns out this is a big no no.
Going forward I'll only use genuine Canon cartridges. I certainly didn't save any money this way.
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
