11-20-2018
02:27 PM
02:36 PM
I have a Maxify MB2720 that starting skipping lines in MS Office 2013 products (outlook, excel and word) will print with other programs. ANY HELP?????
11-26-2018 09:27 AM
Hi jen121361,
A test of your MAXIFY MB2720 should be performed. This will tell us if the printer is working correctly. To do this, please load letter-sized paper in the MAXIFY MB2720 and follow these steps:
1. Swipe the HOME screen and then tap Setup on your MAXIFY MB2720.
2. Tap Maintenance.
3. Tap Print nozzle check pattern.
4. Tap Yes.
The Nozzle Check will print. Please compare your printout to the example that has been attached to the bottom of this post. If they differ, please perform a few printhead cleanings.
To perform cleanings, please follow these steps:
2. Tap Maintenance.
3. Tap Cleaning.
4. Tap Yes to clean the printhead.
5. Tap Yes to print another Nozzle Check.
Does the Nozzle Check print correctly? If not, please contact our support group using the following link:
http://Canon.us/ContactLI
12-06-2018 09:05 AM
The print pattern is missing half of the black and I deep cleaned it and still no change.
12-13-2018 11:17 AM - last edited on 12-13-2018 11:22 AM by Porcha
Hi Jen121361,
Since the deep cleaning did not resolve the issues and half of the black is missing, we will need to check the ink levels.
Please click HERE and follow the steps to check your ink levels.
Once that is done, please let us know what level the BK is at.
01-22-2020 09:05 PM
Mine is doing this!
01-22-2020 09:07 PM
Canon please help. I have done deep cleaning several times.
01-24-2020 01:36 PM
Hi Rgramza10,
Because performing multiple cleanings did not get black to print, please contact our support group using the following link:
06-06-2020 06:21 PM
Did you get a response / resolution on this? Mine is doing the same thing!
06-10-2020 03:13 PM
Hi gambitgerm,
Cleaning the encoder should resolve this issue. To do this, please follow the steps in this Knowledgebase Article:
https://support.usa.canon.com/kb/index?page=content&id=ART168472
07-11-2020 01:40 PM
The Q-tip trick is not working. What else! Printer still missing the bottom half of some lines.
