06-19-2015 09:23 AM
Hello ! I have a Canon MF8280Cw connected wirelessly through wifi to all my computers (all mac os). I used to be able to scan wirelessly with no flaws but for some reason now i am not. Mac shows Error code: 2100010
12-21-2019 07:50 PM
05-06-2018 11:12 AM
04-19-2019 12:46 PM
I've also hit a dead end.
The only way I can get this to work is to unplug the unit and reboot it, and then it works the first time, and not again after. Did you ever figure out a solution?
12-16-2019 03:54 PM
For HOME USERS and SMALL OFFICES:
FOR Apple Mac users, including macOS Catalina.
Go to the printer, select STATUS MONITOR > NETWORK INFORMATION > IPv4 to get the network address of the printer.
Open Canon MF Scan Utility then select NETWORK SCANNER SETTINGS to get the MAC ADDRESS of the printer.
Then HARD CODE the IP and MAC in your Router
This also works for the Color imageCLASS MF642Cdw
04-17-2017 07:29 PM
04-18-2017 09:44 AM
Thanks for taking the time to respond to my question. In the interim since I originally posted I was able to solve the problem and, yes, it is as simple as you've written. Everything appears to be working correctly now.
07-24-2017 04:04 PM
We have a Toshiba laptop that the printer will not recognize. Not listed in the available computers on the printer, uninstalled and reinstalled printer drivers and ToolBox. ToolBox won't open on computer for Scan to. any ideas? Is there a windows 10 setting I should check that may be blocking the printer from talkig to the computer?
12-16-2019 04:08 PM
12-27-2019 02:49 PM
