MF656Cdw A scanner driver supporting this software is not installed. Install it and try again.
jsblume
I installed my Canon Color imageClass printer driver and scanner utility. When I tried to run the scanner utility, I got this message:
I uninstalled and reinstalled both. I've restarted my computer. I've uninstalled both and installed an older printer driver and then the scanner utility again - no luck.
The only solutions I've found in the community is what I've already done.
What is the solution?
I have the latest version of Windows 11 Pro.
Thank you.
GSzabados
Try to install the complete driver package, it is called something like:
(Windows, 64-bit) MF657Cdw / MF655Cdw / MF651Cw Drivers (Generic Plus UFR II / Generic Plus PCL6 / Generic Plus PS3 / Generic Fax Driver / ScanGear)
I was struggling with the same problem, because the suggested driver is only the printer driver, but not the scanner driver.
3 REPLIES 3
GSzabados
jsblume
Thank you! That did it. I modified your search string for my printer model and found the installer.
Outstanding! It solved my problem with my MF424DW. Thanks!
