04-25-2020 09:05 AM
ONE paper tray soooo
changing to new paper size, e.g. 8.5x11 to 4x6 inches
user is FORCED to go through 10-14 paper size choices on the printer EVERY CHANGE of paper?!?!?!?!?
How to either DELETE never/seldom used "stock sizes" with ability to add them back later (BEST SOLUTION)
or at least have DEFAULT Paper A and Paper B posted as the #1 & #2 choices to "register" on printer upon every paper change?
Noooo I DO NOT want another front + rear paper feed source, thank you very little ... same hassle only with feeding issues constantly!
05-06-2020 08:32 PM
HI tgivaughn,
You won't be able to remove any paper sizes from the list but there are ways around having to select the paper size on the printer every time you load paper. You can go into the settings and you can turn off the settings for detect cassette reinsertion and detect paper settings mismatch. To turn the settings off, you can follow the steps below.
After changing the settings you won't need to select the paper size on the printer whenever you change paper. The only place you will need to select your paper size will be on the device that you are printing from.
