11-28-2012 12:16 PM
I got this after installing new ink - it worked just a bit and then when I turned printer off and on, got this msg. I took out cartridges and head, put them back in, and no change.
05-02-2014
11:36 AM
12:27 PM
Stephen
I had this error with my canon printer that showed up one day with no warning.
Using my powers of deduction and understanding how power supplies work I found an easy solution to fix that that anyone can do in about 1 minute.
If you would like to know how to do it email me.
Removed email address per FORUM GUIDELINES
05-06-2014 11:23 PM
I am surprised Canon is brave enough to have a public forum. The MX700 printer is loaded with defects one of which is the print head. I threw mine in the trash bin. DO NOT buy a new print head or ink for this model. No matter what you do it will not work I quarntee it.
I seldom join these circle forums because I have other gadgets to play with. Also is it really worth being having your email inbox spammed day and night. Well in this instance yes.
Canon the MX700 is a pile of rubbish and am surpised you take no responsibilty. Trust me the product id defective and one day you may hear from me again.
05-06-2014 11:24 PM
This printer is a piece of junk.
08-07-2014 03:42 PM
08-09-2014 01:31 PM
08-27-2014 07:26 PM
im i lucky or what but it worked after first attempt. thanx
09-13-2014 02:58 PM
This solution did not work :((
09-17-2014 04:17 PM
I have had my printer for about 4 or 5 years now. It has always worked perfectly. Then all of a sudden I get the message that the print head is incorrect and to reinstall it. I turned it off and unplugged it and it worked for 1 print job and then went back to giving me this message. I took out my cartridges and put them back in, unplugged it, etc. VERY upset that I can not do A single thing with it. I try to go into the menu, settings, etc. and am unable to do so because of this error message.
09-17-2014 09:16 PM
I was working with the moderator on a solution. She's disappeared now and I have THREE Canon printers with issues(two of them with the infamous message that we're all seeing)
09-18-2014 06:58 AM
