05-30-2014 04:21 PM
I have a MF6590 mutifunction printer. It had been working fine until last week when I got the error message "Cannot communicate with scanner.." I tried uninstall and reinstall te driver, I tried switching to a different USB port, reboot my PC, turned on/off the printer.. hopped on one foot...nothing worked. Anyone has any suggestion?
03-31-2017 09:28 PM
Have a Canoscan 8400f and a Mac 10.9.5. Everything was fine until "it cannot communicate with scanner." Rebooted the computer, turned on and off the scanner, checked all the connections nd still nothing. Any help is surely appreciated. Thanks.
09-29-2017 03:02 PM
Hello
I have a Canon 6530MF
I have the same problem - Can't communicate with scanner, cable may be disconnected...
I am on windows 10 and my driver is Cannon MF Toolbox 4.9.1.1.mf18
Everything has been working fine and then this started happening
The printer always works, just the MFToolbox -scaner does not work
I saw the previous post, and uninstalled the driver and reinstalled it..... then the scaner works again... for a week or so then it stops working.
It has now happened 5 times, and again I reinstal and it starts working again
It definatelly happens if I reboot the computer, but now I noticed that even without rebooting, and actually leaving the program open, it did it again
I can do a temporary fix by reinstalling it again, but it's getting a little anoying and I would like to find a fix to what's causing this
I looked for programs that I've installed since this started happening and I don't see anything that I think might be causing this
Here they are just in case
DELL SUPPORT ASSIST
DELL SUPPORT ASSIST AGENT
GOTO MEETING
MICROSOFT VISUAL C++ 2015 REDISTRIBUTABLE (x86) 14.0.24215
MICROSOFT VISUAL C++ 2015 REDISTRIBUTABLE (x86) 11.0.61030
SKYPE
DROPBOX
MICROSOFT ONE DRIVE
GOTO OPENER (LOGME IN)
I would appreciate any advise you can give me
Thanks
10-11-2017 10:56 AM
Hi New Contributor,
I will be happy to help. In order to properly assist you with the scanning issue, I will just need to know what operating system you are running?
Please note, Canon's Forum is not intended for immediate help, but a place to allow for the Community to give you assistance and feedback. If this is an urgent support need, please use the link below to reach our friendly Technical Support Team:
http://Canon.us/ContactLI
01-16-2022 07:31 PM - edited 01-16-2022 07:31 PM
Firstly you need to download the latest Canon MF Toolbox from the Canon website. Go to this link to enter your scanner’s model and follow the on-screen instructions to download the utility.
Once downloaded, install the application.
Once installed, right click on the application icon and select
Move to the compatibility tab and select the checkbox behind “Run this program in compatibility mode for”
From the drop-down list, select “Windows 7”
