03-12-2026
05:43 PM
08:19 AM
Canon TR7020a: Scanner is not found. Printing documents from my Macbook Pro using the wifi connection works fine. When attempting to open the Scanner, using the Systems Settings > Printers & Scanners > Open Scanner mehod (which has always worked since I bought the printer), the Scanner window opens but is blank and nothing ever appears. When using the Canon IJ Scan Utility Lite app, the utility window opens, but when I click on Auto or any other button, it searches for a scanner for a few seconds and then I get the "Cannot communicate with scanner" error message.
Any suggestions are greatly appreciated, thank you.
03-13-2026 12:34 PM - edited 03-13-2026 12:36 PM
You many need to install or reinstall the Mac setup driver. It is located here, make sure you match your current Mac OS to the driver.
03-20-2026 03:17 PM
Thank you for the suggestion. I tried this several times without success, no change. So then I deleted the printer from the list of Printers & Scanners, deleted all printer drivers from my Macbook Pro, emptied the Trash folder and started from scratch, as if I was installing a new printer "fresh out of the box".
I reinstalled the driver and now I have a disaster. Now, when I Add printer in Settings > Printers & Scanners, I see the "Setting up 'Canon TR7000 series ...' window (like it's setting up the printer), but then it does NOT add the printer ... let alone the scanner.
Interestingly, I can print from my iPhone. I guess that uses the AirPrint function of the printer?
Now what should I do ??
03-20-2026 06:17 PM
Did you take these steps before running the setup file?
~/Library/Printers/ and delete any files related to the printer you just removed.~/Library/Caches/ for any printer-related cache files and delete them.03-21-2026 07:13 PM
I went thru this procedure meticulously and got the same result. When I go thru the Add Printer procedure, I see the "Setting up 'Canon TR7000 series ...' window (like it's setting up the printer), but then it does NOT add the printer ... let alone the scanner. If I go to System Settings > Printers & Scanners there are no printers listed. While in that window, I click on the "Add Printer, Scanner, or Fax..." button, I just repeat the entire procedure again but there is NO printer added. It's a vicious, useless, cycle. But once again, I can successfully print from my iPhone.
I am seriously dazed & confused.
03-21-2026 07:29 PM
There is a full full installer package available listed under Sequoia OS. You didn't mention what OS you were running? Not sure if this will work under Tahoe but it's certainly worth a try If you're running that OS.
Tahoe uses AirPrint but there is an IJ scan utility lite available.
https://pdisp01.c-wss.com/gdl/WWUFORedirectTarget.do?id=MDIwMDAwNTMxNzE4&cmp=ABR&lang=EN
Right now there's a lot of inkjets relying on AirPrint under Tahoe ☹️ instead of having a dedicated driver.
03-22-2026 02:04 PM
I am currently running Ventura 13.7.8 on a Macbook Pro 15-inch, 2017. And I downloaded the recommended driver package for Ventura. Should I try a different version ?
04-03-2026 12:29 AM
I have tried using several versions of the Canon driver software, all with the same result: now I can NOT use the Canon TR7020a for printing OR scanning from my Macbook Pro 15-inch, 2017 running Ventura 13.7.8
Every time I tried this, I followed the suggested procedure of deleting all printer related apps, caches, etc; then emptying the Trash folder, and restarting the Macbook Pro. I also RESET the printer. When I then download and run the selected driver version, the Macbook Pro "sees" the "Canon TR7000 series ... Bonjour Multifunct" printer, but when I click the Add button, I see the "Setting up 'Canon TR7000 series ...' window, but when that disappears, THERE IS NO PRINTER ADDED.
Interestingly, I can Print & Scan from my iPhone xR using the Canon PRINT app, so I think the printer is OK, there is something wrong with my Macbook Pro to Canon communication. This worked fine up a few months back. I hadn't tried to use my printer until I started on my taxes.
HELP !!
04-03-2026 08:16 AM
Give Canon support a call at 1-800-OK-CANON.
04-08-2026 11:28 PM
Apparently, during all the deleting and reinstalling cycles of the software for the printer, I deleted the innate AirPrint driver. Long story short, I had to reinstall the Ventura iOS, and that fixed the problems I was having. I can now print and scan from both my iPhone and my Macbook Pro. Thanks to everyone for your suggestions.
