08-13-2023 04:49 PM
My canon r6 doesn't have the Bluetooth icon in the menu section.
I also tried updating the firmware from 1.0.0 to 1.8.2 but I get "Update file cannot be found. Please check the memory card and reload the battery and try again" error message instead.
08-13-2023 10:27 PM
@Midwaymonstr,
Congrats on getting the new FW loaded. If my steps were followed, you should have reset the camera's settings (main and custom) in P or M mode before the FW upgrade.
Do you have the camera connected to anything? Like a USB-C connection?
Please provide more details on the wireless / bluetooth status. Using P or M mode, what you are / are not seeing, etc.
Canon : Product Manual : EOS R6 : Wi-Fi/Bluetooth Connection (start.canon)
08-14-2023 10:05 AM
I read through the manual and it doesn’t say anything about troubleshooting Bluetooth or Wifi
so basically I can’t make the Wi-Fi work or Bluetooth. I keep typing in my wifi password and then all it does it try’s to connect but times out. Dial Setting is at P as well.
08-14-2023 10:08 AM
If you need one-on-one help, feel free to reach out to support at 800-OK-CANON (800-652-2666), Monday through Friday from 9am to 9pm (ET) or Saturday from 9am to 8pm (ET).
08-14-2023 10:10 AM
Starting on page 550, the manual shows how to set up Bluetooth. Have you tried following the steps in the manual to set it up?
08-14-2023 10:36 AM
@Midwaymonstr,
Providing accurate concise answers to our questions is important and helpful. 🙂
You haven't told us:
-If the camera is connected to something USB-C (like your computer)?
-If you performed the full reset (main and custom) settings prior to the upgrade?
The bluetooth menu option enable/disable you took an image of is a sub menu of the Wireless Communication Menu. If you don't have that menu option, how are you getting to the Bluetooth settings page?
08-14-2023 11:58 AM
The camera is not connected to anything.
I did reset Basic stuff but not sure if I should be resetting other things?
I also went to Bluetooth, Click on Enable and nothing happens.
the antenna icon is not on the menu. Not sure if something or a setting is preventing it from connecting to Bluetooth/ Wi-Fi 🤷🏽♂️
