What should my first sense be for EOS T5 camera
What should my first lense be?
My 5D Mark III 's lcd screen suddenly quit. Changing batteries, cards, lenses or hitting any buttons inc. menu doesn't help. It still takes pics. Just the back screen doesn't come on.
I can no longer transfer photos from camera to computer. I used to be able to but something happened. I can't even seem to transfer using card reader either. Any suggestions?
I've been having issues with the speedlights misfiring on my 5D miii since I purchased the camera. I've had the camera and flashes in a numer of times over the past two years to try and troubleshoot the issue. They've blamed the hotshoe (replaced twi...
Aloha! I have a Canon 7D. It won't turn on with a lens attached. The body alone turns on fine, but when attaching the lens, it shuts down. It isn't the lens because I tested it on a 5D with no problem. Ideas? I cleaned the contacts with alcohol, but ...
SL1 body. When pressing the Q Set button it always defaults to Image Quality and does not allow me to manually change to other settings using the arrows. I know I can use the touchscreen to do so but I've been a Rebel T1i user for many years obviousl...
Old laptop died so I just bought a new one w/ W10. Where can I find the software download for EOS utility so I can get back to getting my photos on the computer? On the Canon website, I only found an update, not the actual software. Tx
I want to take pictures of the boat parade this weekend but have no idea how to set my camera. It will be dark, the boats will be brightly lit and moving. Any suggestions, anyone? Thank you so much!
Canon T2i busy light stays on when a photo is attempted. All the menu functions seem to work
I'm still learning and was reading a book that says the "P" (Programmed Mode) sets everything automatically. So my question is what's the difference between that and the 'auto' (A+ Scene Intelligent Auto mode) mode?
My Canon 550D SLR won't focus properly, can any one help? Thank you!
I just bought a Rebel T3i and find that the Canon Camera Window that I have used with previous Canons to transfer photos to the PC (Windows 7) via Zoombrowser couldn't be accessed with the T3i. So I am using Windows Photo Gallery but liked the Camera...
I'm using an XLR to Mini Jack converter box (DXA-2T) in the EOS Rebel LS1 - I'm getting low volume and static - when I use the SAME setup in another camera (Sony handycam) audio is fine. Any thoughts or suggestions?
Hello,I have a 70D that I purchased in 2014. I took a few photos and then the camera froze after pressing the shutter. It would not turn off without pulling the battery. Thinking it was a battery problem, I charged the battery and tried it later that...
When I set a shutter speed and aperture in manual mode after measuring the actual ambient light with a separate light meter, the exposure appears typically underexposed. Am I missing something? The ISO's between meter and camera match, etc.
| Subject | Author | Posted |
| 08-31-2026 08:09 PM | ||
| 05-19-2026 01:06 PM | ||
| 05-14-2026 07:24 PM | ||
| 04-22-2026 11:08 AM | ||
| 12-18-2025 01:20 PM |
