New to R5 M2 (coming from the R5) - where is the Face Tracking AF Method?
Am I missing this button setting? I'm so used to the AF Method being the cute face + Tracking setting but I just don't see it on the M2. Is that correct?
I had a Canon Rebel camera that kept producing weird dots in photos so I purchased an EOS 2000D. I am having the same exact issue with this camera. Recently went to an air show and took 659 pictures with 2 different lenses. Dots appear in all 659 pic...
Hello,I just got my canon eos r10 not even a week ago. Today, for a school project, I shot some videos with it outside. It was quite hot and the battery did die mid-shoot. Up until then everything was fine, but once I charged it suddenly it started l...
Hello everyone. This is to inform all R5 Mark II owners that a new firmware Version 1.3.1 is available/released as of 6.5.26. Yesterday I received a Canon email "Firmware Notice" informing me of the New Firmware Version 1.3.1. So today 06.07-26, I ...
Location: UK.My M50 has just decided to forget my wi-fi router. The router is not in the list. It sees many of the local routers in the set of flats here, so it does not seem to be a distance issue. The camera is in the same room as the router.This ...
How do I find & adjust the shutter speed on the Canon 4D(40D)?
I have a Canon EOS90D. My camera started not focusing or metering and I get a clean contacts error message. I tried the lense on my other camera and it worked fine on it. Tried other lenses on it and same thing happens. I have got it to work a fe...
I have had zero success getting the WiFi to connect to the camera to transfer photos. It automatically switches from Bluetooth to WiFi and just stays in that mode for up to 30 minutes before I shut it down. I have read past posts about it and see tha...
Whenever I attach a zoom lens into my camera, use my LCD instead of my viewfinder then if I zoom in and then zoom out, my LCD goes blank and it switches to my viewfinder, sometimes I get this error :https://i.imgur.com/1QlMlsB.jpegHere's a video I re...
I recall from an earlier camera that getting these two to talk with each other is finicky, but happening again. I have gone through the early steps of the process -- enabling WiFi, giving a nickname to the phone, opening WiFi on phone but the nicknam...
I have an R7 on which I use an EF 400 5.6L and a Canon EF-RF adapter, primarily for taking photos of birds. I have noticed that most of my pictures are backfocused. It is as if the camera is not taking into account the extra distance the adapter puts...
Hello,Just got this camera about a month ago in late September. Im running into a problem where the quick control dial when turned left, goes both left and right erratically even though I’m only turning left. A temporary fix I found is lifting up the...
Hi everyone, I'm hoping someone has seen this before, because I'm running out of ideas. My equipment Canon EOS R5Firmware: 2.2.1Canon Mount Adapter EF-EOS R (original Canon, brand new, purchased from Amazon)Canon RF 14-35mm F4L IS USMCanon EF 24-105m...
My EOS R6 MARK II camera, running firmware 1.7.0, does not give me the menu option to connect to a wireless remote as many YouTube how-to videos show. It only shows enable/disable wi-fi and bluetooth settings selections in the menus. No "Add a device...
| Subject | Author | Posted |
| 09-11-2026 10:00 PM | ||
| 09-09-2026 07:25 PM | ||
| 05-19-2026 01:06 PM | ||
| 05-14-2026 07:24 PM | ||
| 04-22-2026 11:08 AM |
