03-17-2025
01:54 PM
08:46 AM
Just tried to set up a repair request for this for my Canon R6 and got an estimate of $405. Why is it so expensive?
03-17-2025 02:06 PM
I believe they need to disassemble the camera to reach the screws from the inside.
03-17-2025 02:09 PM
Yep.
03-17-2025 02:25 PM
Not to mention Canon doesn’t know how much work may be required without having the camera in front of them. To see the scale of work that is only an estimate. The price will be adjusted accordingly depending on what needs to be repaired or replaced.
03-17-2025 03:19 PM
I thought it had gone up to $500 now, unless you are counting on the 20% CPS Gold Membership discount. I have gone through 3 such repairs on my 5D mk III, R5 and R6. I don't even mount speedlights on the hot shoe any more (using transmitter and improvised bracket with cold shoe)
03-17-2025 03:51 PM
This is a costly repair, but honestly it's one you want Canon to perform. Peeling off the outer skin alone is cringe-worthy. Imagine if you couldn't get it back on. There are YouTube videos on the repair too. The ones where they show the complete repair, but with screws left over are also classic. This repair is best performed by Canon.
03-17-2025 05:55 PM
Thank you for all the responses! Do you know if they clean your camera in addition to the repair?
03-17-2025 06:10 PM
I think they do for all repairs.
08-01-2026 09:57 PM
Did you send it in after all? What did they end up charging you? Also, how long did it take them to fix? I have the same issue with my R5. Thanks
08-02-2026 10:30 AM
"Did you send it in after all?"
Over a year ago thread I image all have moved on.
