04-11-2026 09:19 PM
The lens collar on my RF 200-800 has had a small amount of play in it since day 1. It does what it's supposed to do and does not rotate when tightened, but when you pick it up by the lens foot, you can feel the play. When the collar is loose and able to rotate freely, there is a lot more play.
I use a monopod and a Wimberley WH-100 MonoGimbal, so I am always loosening and tightening it. I have emailed Canon support about it and their answer was that it was designed that way, and as long as it does not rotate when locked, I am good to go and if it gets worse I can always send it in etc....
Does anybody else’s rf 200-800 do the same? If so, any fixes? I tried putting a lens band next to the collar but it did not really do anything. I know its not L glass and I try not to let it annoy me, but it does. I wish the collar was removable so I could put some tape on the inside or use a 3rd party one like the rf 100-500. I have the carepak on it and CPS gold. I don’t really feel like sending it in now because I use it everyday especially now that the weather is getting nicer and my guess is it would come back to me saying it is within tolerances. I will probably end up sending to canon in the fall/winter anyway. I guess for now I will just keep shooting and try to ignore it .
04-28-2026 07:09 AM - edited 04-28-2026 07:18 AM
Quick update. Got the lens back Friday, 5 days door to door for CPS which was awesome. Even though they replaced the collar it still has some rocking like my first video with the knob fully tightened. It's a little better than before but it's still there. With the knob fully loose and able to rotate the wiggle is about the same as my second video at least I can't tell the difference . I used the lens Friday and all weekend and my keepers look as good or better than before so no complaints there. I am not sure if sending it in actually accomplished anything besides giving me a little more peace of mind that everything is within spec and now I have a box with some custom shaped foam for the lens in case I need to send it back to CPS in the future. Oh well I guess this is the way my copy is. It does not affect the actually lens and I am probably more hyper aware of it now more than ever. I just got to keep using it and taking photos with it until it I forget it even bothered me. 🙂
04-12-2026 08:16 AM
Greetings ,
Sorry you're having an issue with your lens. I own the 70-200, 100-500 and 200-800. The collar's on the first two are solid. No problem tightening and no slippage.
Same goes for the 200-800. Although the collar is not removable, it stays locked in position. I rarely use it to shoot vertically. There is nothing serviceable by you, so I recommend you send it to Canon as you mentioned. It's still a little early, but we're heading into one of the busiest times of the year for service. If you don't send it now then I'd wait till fall.
04-12-2026 08:55 AM - edited 04-12-2026 09:03 AM
Thank you for the info . I am not sure if i explained it correctly in my original post. When locked I have no rotation at all it does its job but when locked it has small amount vertical play (rocking) that you can feel when you pick the camera up by the lens foot or if I hold the lens and pull the foot you can feel it. And I also asked them about the play when fully loose . Canon support's response when emailed was -
"A very small amount of play or slight rocking in the tripod mount ring, even when the locking knob is fully tightened, is completely normal and by design for this specific lens model as well as the RF100-500mm. This slight physical tolerance is built in to ensure the collar can rotate smoothly when loosened without binding or scratching the lens barrel. As long as the collar holds the lens securely and prevents it from freely rotating, it is functioning exactly as intended and is perfectly safe to carry by the foot."
"With the collar screws loose we would expect there to be some play between the collar and the lens allowing the collar to move up and down a bit or side to side a bit. As long as the lens and collar aren't fully coming apart, or the lens is still easily moveable when the collar is tightened, it should be okay."
The collars on my EF lens in the past never did this. But according to the people I emailed at canon support this lens is designed that way. I do not know anyone else locally who has one or have a store that sells them nearby to compare mine too so I am not sure if I am on one end of the tolerance and yours might but at the other end. Do other owners of the 200-800 experience this. I do use the collar a lot so maybe I just notice it more. I will probably end up sending it in but it will be fall/winter
04-12-2026 02:16 PM
Now that you have highlighted it I checked and my 100-500 has a very (emphasis on very) slight rocking when tightened down. I wouldn't have noticed until it was pointed out.
04-12-2026 03:28 PM - edited 04-12-2026 03:29 PM
I only notice any rocking or longitudinal "play" on my 200-800 when the locking knob is loosened - none when it is tightened. I have not moved my foot position on the lens a great deal. It is usually being used hand-held with the foot locked in the 4 o'clock position. I've attached it to a monopod and tripod only a few times. I'm assuming it will get some experimental use on an astro mount some clear days this summer, but that hasn't happened yet. I would find any movement in that situation particularly aggravating if it were spoil the shots for stacking. That said, based upon what I'm experiencing with my foot I don't expect that to happen.
This is the same situation on the feet of the EF 70-200 f/28 and RF 70-200 f/2.8 Z that are currently in my possession.
04-13-2026 06:45 AM
Thank you guys for the replies. The rocking when fully tightened on mine is pretty minimal but just enough to bother me. You can only feel it if you pick the camera up by the foot due to the weight of the camera and lens or when carrying it by the foot. I always have to move the collar around when putting my it in my backpack so it fits. I also keep it at the 4 o-clock position when using a strap attached to the foot and handheld. When using the Wimberley MonoGimbal, I keep it loose on it so it can rotate when panning but the play when loose does not effect anything you cannot even feel it on the gimbal. I am constantly tightening and loosing the locking knob between putting it in my backpack and using the gimbal hopefully it does not get worse over time.
It's interesting to see all the tolerance differences . I am sure I am towards the looser end but still within “acceptable tolerances” Its a shame the collar is not user removable. That is pretty much my only gripe with the lens besides that I love using it and it has been my most used lens since getting it.
04-15-2026 08:28 AM
I have had mine for 18 months now and have not noticed any rocking when secured. I have used it on tripod a few times and was very solid. The rest of the time it is locked to the side, I carry it with the foot often and there is no play.
04-15-2026 08:16 PM
I've had mine [200-800] for about a year and use it 50/50 monopod and hand held. When locked, there is no play in any direction. When unlocked to rotate, there is some wiggle, but it's what I would expect it to be, that is, I don't feel like it's not supposed to be that way... If that makes sense 😁
Newton
04-16-2026 09:08 AM
Mine is brand new and when I checked it at first I noticed a small wiggle but then I gave the locking knob a small extra turn and it tightened up.
04-16-2026 11:01 AM
I'll pull mine out today and check but, I If I recall correctly mine has no movement like Newton's @FloridaDrafter's lens.
