R5 card settings
I can't figure out how to set the camera to record each pic jpeg on one card and raw on the other. I have this setup on my 5d IV and it works well for me.
Hello, i am new to photography/videography. I just purchased a used Rebel T6i 750d camera and has the 18mm-55mm lens. I am going to start recording/ documenting my outdoor adventures. (mainly hunting and fishing.) Can i add a VariZoom LANC Zoom Con...
Hello, I'm new to the community and to the Canon 70 D , I would appreciate it very much in someone can give me the best movie settings for my Canon 70D . Thanks very much.
I am a beginner videographer, and recently purchased the canon sl3. I have tried shooting video in manual mode but ran across a problem that other people that I know with SL3s have not had. When I film in manual mode, the exposure and ISO both show u...
Hello,I cannot figure out how to adjust the image quality on my camera. I read the manual and did it for the best quality images, but it still shows blurry when I take photos. Could anyone help?Thank you
I have downloaded the Canon webcam utility and I'm running it on a mac with macOS Catalina. I'm using a Power cord, and a USB cable. The picture is incredible and it runs fine most of the time. However from time to time, every 30 minutes or so, the c...
Anyone here use an RP and experience autofocus issues with non-canon EF lenses?I have a sigma 105mm macro 2.8 and a 100-400, both attached using a RF-EF Adapter. Occasionally the autofocus seems to stop working usually when I’ve not taken a shot for ...
Hi Folks, Hopefully this isn't a huge issue, but I'm worried. While I was using my 70D with the Webcam utlity, the camera froze up, and then started showing a white screen with vertical lines about 1/3 of the way up from the bottom. When I take a p...
Hello - I have been shooting Canon cameras since the mid '80's. Recently I had to return the EOS R5 due to it being defective. A replacement order was placed. I received the replacement order Tuesday at noon on 11/10/20. I noticed toni...
hello i have a Canon Eos T3i Rebel and am starting up a youtube channel. since then i have purchased a JOBY tripod and a RODE VideoMicro microphone. when i got the microphone in it has a 3.5mm male to a 3.5 mm male connecting cord. well the t3i has a...
Hello there, I have a 40D with the kit USM lenses that the autofocus stopped working completely.The camera takes pictures fine with manual focus, but I'm trying to fix this issue so I can use it as it was intended.Firmware version is 1.0.8 Some thing...
The heat from a Canon LP-E6N battery interferes with the sensor during minutes- to hours-long exposures, its thermal radiation causing ill-effects which ruin photographs of deep-space objects. I’ve encountered this following exposure in as little as...
I have an relic from days past and it doesn't seem like this model wants too work with the Canon webcam utility. It's not listed as supported. Will a capture stick work? I'd love to find some use for this camera but if I can do this without spending ...
I have an EOS Rebel T6i, which i bought during end of November 2018, Exactly after a year or the warranty ends, i started facing the issue as "Card's write protect switch is set to lock". This issue happened when i was shooting the pictures on a cele...
I have been using the camera connect app for over a year and it has worked perfectly. I got a new IPhone 11, reinstalled the app and now it takes almost 5 minutes to import ONE picture. Any suggestions????? I have a Rebel T6.
| Subject | Author | Posted |
| 09-12-2026 02:17 AM | ||
| 09-11-2026 10:00 PM | ||
| 09-09-2026 07:25 PM | ||
| 05-19-2026 01:06 PM | ||
| 05-14-2026 07:24 PM |
